Thread: Filling pool with new liner
    I had my above ground liner replaced tonight at 5, the pool has been filling since 6:30. The temp has dropped to 52 degrees. Is it too cold to keep filling the pool? The pool has about two feet of water in it now. Can I stop filling and start again in the morning?
    Thank you for any help
    18'x54" 7,617 gallon AG, Clear Water ll 2 speed cartridge filter.
    Taylor K-2006
    BBB Method
    Southern New Hampshire
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: Filling pool with new liner
    Its not too cold at all. If you are nervous about it, you can stop and start again tomorrow.
    Divin Dave,
    Thank you, I stopped filling it, the design at the top looks like it is being stretched out of shape. I wanted to make sure it was safe to stop with it partially filled. I don't want to cause any problems this is our second liner and we just got the pool last July.
    Taylor K-2006
    BBB Method
