Thread: CDC Hot Tub Advice
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,643
    CDC Hot Tub Advice
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: CDC Hot Tub Advice
    Ok, so we should panic over a report of 16 incidents reported to the CDC in a 1 year calendar period with probably millions of operating hot tubs, many of which are poorly balanced? Personally I feel safe in my hot tub, I test the chlorine and pH before each use, have an SWG, an Ozonator, and a Nature2 mineral cartridge (admittedly the cartridge is not changed on a regular schedule)
    Mar 2007
    San Rafael, CA USA
    12,082
    There are way more than 16 incidents of hot tub rash/itch/lung in a year. Most residential incidents do not get reported to the CDC. This isn't the same as reporting from commercial/public pools nor reporting of more serious diseases. Just on one spa forum alone I accumulated a dozen or more such incidents. The most common cause was using too little or no chlorine (sometimes due to use of "alternative" sanitizers, which really weren't). Use of Dichlor-only building up CYA over months may also be a cause but there were too few of those incidents to be sure.
    Properly chlorinating with the Dichlor-then-bleach method has not led to reports of these problems and its been a few years now since that was started.
    Jan 2013
    St. Pete Fl.
    6
    I wonder how many monitor and change out the water on a regular basis which very important with the high temps found in a spa.
    44,000 gallon, Plaster pool, Hayward C4025 cartridge filter, 5hp pump, Geothermal heated to 87, Chlorine, with Rain curtain feature that has its own 5hp variable speed pump. A Detached Tiled Spa, 650 gallon, C1750 cartridge filter, Geothermal heated to 103, Both are IG but on the 4th Floor, the Equipment rooms are located on 3rd floor. (this is the pool I take care of at work)
