Thread: Filling up.. 2 legs not on pavers.
    Hi. Filling up my intex 14x42 right now and I noticed 2 of the legs are not on the pavers anymore. (they were dug level with the ground). We have some pretty hard base anyway, was just trying to go the extra step. I have the pavers to far out from the pool, was scared for the to rub against the edge. Anything to worry about ?
    mac.dblues's Avatar
    Jul 2013
    Arkadelphia, AR
    321
    Re: Filling up.. 2 legs not on pavers.
    If the pool isn't too full, I think I would try to move them. You may have a solid base, but those two legs are going to have more ground pressure on them then the other 12 legs that are still on the pavers.
    Mac.Dblues and ProfessorDaisy's Lower Arkansas Pool Install
    Intex UltraFrame 20ft x 52in deep, 9,400 Gallons / Approx 78,500 lbs, Intex 1600 GPH, 14" sand filter, Hayward Dyna-Skim SP1091LX, Taylor K-2006, SpeedStir, Sample Sizer
    First Fill May 2014, Deck finished June 2014, Mods happening probably on a continuous basis. Stay tuned.....
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Yup, its one of those things where all the legs need to be on the pavers.... Because they will eventually sink further into the ground than the pavers and make your pool unlevel.... Its best to get it right the first time....
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    Too full now to move. the ones that aren't on are currently the high side by about 1/2 inch so if it does sink on the side it would be better. I'll watch for now.
    mac.dblues's Avatar
    Jul 2013
    Arkadelphia, AR
    321
    It will probably be OK just keep your eye on it. There is a thread on here somewhere detailing how to jack up a post to let the pressure off so you can repair the paver.
    I think I might do that. Nervous that the legs are right at the edge where the pavers are which is loose dirt since it was dug. Really want to get the legs under.
    Rain forecast for tomorrow. We shall see how it holds up. Right now I'm still off almost an inch.
