Results 1 to 10 of 10
Thread: Concentrated bleach and poolcalculator
    Pysiek's Avatar
    Apr 2012
    Frankfort , Illinois
    419
    The only bleach available in my area is the concentrated bleach. On the bottle it says 121oz=182oz. Now my pool is 24000 gallons. I go to poolcalc and type FC=0 Goal=10 . Bleach is 8.25%. It shows me to add 362oz of bleach. Is that mean that I have to add 362oz of the concentrated bleach? Or should I used it differently since it's concentrated?
    30'x54" Quest Above Ground Round Pool , About 21,000 Gallons , Hayward Perflex EC50 D.E. Filter System 1.5HP Power-Flo Pump , TF-100 Test Kit , Two Hayward Main Drains on the Bottom , Hayward CL200 In-Line Above-Ground Chlorinator.
    77"x77"x21.5" Hot Tub
    JesseWV's Avatar
    Apr 2011
    North Central WV
    526
    Re: Concentrated bleach and poolcalculator
    Are you using www.poolcalculator.com or the PoolMath link at the top of the page?
    16k gal, 28'x3.5', Vinyl A/G, 1hp Pentair Dynamo 2-speed Pump, Hayward S160T Sand Filter, Intermatic HB800RCL Digital Timer, Intex 8110 SWG, TF-100 Test Kit, SpeedStir Author: Jesse's Graphical Pool Testing Log
    Pysiek's Avatar
    Apr 2012
    419
    JesseWV's Avatar
    Apr 2011
    North Central WV
    526
    Aaah. poolcalculator.com hasn't been updated in some time and does not include the newer bleach bottle sizes or concentrations. Use the PoolMath link at the top of the page.
    38,248
    poolcalculator.com is abandoned by its current owner. PoolMath is an in-house version that we are keeping updated.
    Pysiek's Avatar
    Apr 2012
    419
    I thought they are both the same thing. Okay but still do I just add 362oz as recommended per PoolMath?
    JesseWV's Avatar
    Apr 2011
    North Central WV
    526
    They look very much the same but the difference is in the details. PoolMath is up to date.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Quote Originally Posted by Pysiek View Post
    Add what it says. The concentration is accounted for in the percentage.
    Pysiek's Avatar
    Apr 2012
    419
    Quote Originally Posted by JohnT View Post
    What I understand is before it was 182oz and 6% and now is 1210z but 8.25% ? I'm I thinking right?
    JesseWV's Avatar
    Apr 2011
    North Central WV
    526
    That is correct. PoolMath knows about the new 121 oz jug size so select that and enter the new 8.25% concentration. As long as these are set correctly, your pool volume is correct, and you've plugged in your current and target FC, the amounts it says to add will be correct.
