Thread: "High Salt Level" flashing on my Circupool si Series SWG
    May 2014
    Milan, Tennessee
    2
    My SWG has been flashing "high salt". I have been draining water & adding fresh all wknd. Last night it read 4500 ppm. I got up this morning and it jumped back up to 4900 ppm. How could I have more salt than 12 hours prior, when none has been added? Not to mention, my test strips show my salt levels way lower than that! Help!
    38,275
    Re: "High Salt Level" flashing on my Circupool si Series SWG
    Welcome to TFP!!!
    I would get another independent test of your salt level ... what does a pool store think you salt level is?
    Most SWG have 2 salinity readings. One is an average and one is instant ... they may not match perfectly all the time.
    Jul 2007
    Hillsborough, NC
    525
    Or get a salt test kit, and test the water yourself. this is the one I have. The first time I used it I had the pool store test the water, the readings were close so it seems accurate.
    http://www.amazon.com/TAYLOR-TECHNOL...+salt+test+kit
    27' Round Might Sun AG Pool 18000 Gallon Intex Krystal Clear SWG Hayward Pump/Filter on a Timer
    May 2014
    Milan, Tennessee
    2
    Thank you. Unfortunately, it doesn't matter what my test strips say b/c my SWG won't produce chlorine if it doesn't read between 3000-4000 ppm. This cell isn't even a year old, so I'm concerned it's defective. I'll have to run a sample up to the pool store and see what they recommend.
    Oct 2013
    Chapin, SC
    1,141
    My si45 has had a flashing high salt reading since installation. The instant has been reading over 5000 and is generating chlorine just fine. They are supposed to stop generating at 5500ppm and 2500. If it doesn't stop, don't worry about it.
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
