Thread: PH Question
    Task's Avatar
    Sep 2013
    West Grove, PA
    232
    PH Question
    I've noticed that my PH seems to always rise to about 7.8 and then it seems to level off. The water is still a bit cold, but the kids have been playing in it on the really warm sunny days, but their hasn't been a whole lot of splashing and I don't keep my return jets pointed toward the surface so their really isn't much if any aeration going on. It seems that when I check my PH everyday, it is at 7.8. I was adding a bit of MA to bring it down to 7.5 each day, but it always seems to jump back up to 7.8 within a day or two. When I don't add the MA to make the small adjustment, it just stays at 7.8.
    Is this something that is normal? Should I just not bother making the minor adjustment unless it rises higher then 7.8?
    16'x32' Inground Vinyl, 21,100 gallons, Hayward 1.5 HP Super Pump, Hayward Pro Series S244T 3.1ft Sand Filter
    TFTestKits, Pool School, ABC's of Pool Water Chemistry, Chlorine/CYA Chart, PoolMath
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,055
    Re: PH Question
    What is the TA level? If it's high, it will drive pH up. You can safely knock pH down to 7.2 and buy yourself a day's rest, too.
    38,475
    Re: PH Question
    If it stays at 7.8, then I might suggest just leaving it there if everything else is in range. Just make sure it does not go above 8.
    Task's Avatar
    Sep 2013
    West Grove, PA
    232
    Re: PH Question
    TA was at 150 when I checked it on Thursday afternoon.
    (I'm pretty sure it was 150 if my memory serves me correctly. I'm at work right now and I have my chart of test results at home so I wouldn't be able to check for sure until later tonight when i get home. Definitely in the 150-160 range though)
