Results 1 to 13 of 13
Thread: PB didn't listen - Phos Free will it cause damage
    May 2013
    North East Ohio
    959
    I really wish PB would listen...
    Ok long story, but I will avoid all that...I have an issue with my filter not filtering and my PB insists I need PHOSFree to help my filter. I tell him NO NO NO NO, but guess what he does. Adds nearly a gallon of it to my skimmer. He says it is supposed to cause a "layer" on top of the filter media, bla bla bla.
    Well, guess what, all that pucky milky stuff just blows right through my filter (what my problem is in the first place) and now my pool has 100 oz of this **** in it. My pool was already cloudy due to not filtering, so I can't really tell what damage, but are these chemicals in the water going to mess me up ? Thanks in advance!
    Components CAS # Percent Composition/Information on Ingredients
    • Lanthanum(iii) Chloride Heptahydrate 10025-84-0 3% - 7%
    • Zinc chloride 7646-85-7 3% - 7%
    • Aluminum, water-soluble salts, n.o.s.*** 1327-41-9 1% - 5%
    14,750 GAL IG Fiberglass (16 x 33) NE Ohio || Jandy 1HP 2 speed Pump || Waterco MultiCyclone 16 Centrifugal pre-filter (removed due to not working with sand filter) || 30" 575 Lb. Sand Filter || AquaCal 140K BTU Heat Pump || Solar Cover || Inter-fab Adrenaline Slide || GLI Monsoon Solar Cover Reel || K-2006C Test Kit || BBB with Liquid Chlorine Stenner Injection || Rayner Mighty Mesh Winter Cover
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Re: PB didn't listen - Phos Free will it cause damage
    Cloudiness after phosfree is very common. Plug Cloudy phos free into the search box above and you'll find many discussions about it.
    38,548
    It will not hurt anything chemically, but you are right it was not needed and apparently made the cloudiness worse.
    May 2013
    North East Ohio
    959
    Yes of course it made things worse...I assume at this point I just continue to try and FIGHT about my filter issue...will it eventually just break down I assume ?
    It will eventually filter out, though that may take a week or two.
    Mar 2007
    San Rafael, CA USA
    12,082
    The cloudiness is from a combination of some lanthanum phosphate and mostly lanthanum carbonate. Both should filter out, but you might need to add DE to your sand filter if you want to speed up the process. Of course, if the fundamental problem is some serious channeling in your sand filter or some other sort of bypassing of the sand, then nothing will really help much until you get that resolved.
    May 2013
    North East Ohio
    959
    Alrighty thanks guys I'm just glad to know there's no permanent damage... Adding de will not work as I have some sort of filter issue most likely from the glass vs sand media but that's another story
    You could try some filter fiber like Jack's Magic Filter Fiber Stuff instead of DE. DE or the fiber should help. It will also help diagnose the filter. If you watch the returns closely for about two minutes after adding DE or fiber, you should see some coming out if the filter is not working.
    Support the site
    May 2013
    North East Ohio
    959
    Yup that's exactly what happens when I had de it just pours out of the returns
    May 2013
    North East Ohio
    959
    Just to ensure, no need to SLAM to fix this....I have a perfectly milky pool this AM with no overnight chlorine loss (well .5)
    Some DE will bypass a sand filter, but it shouldn't be much. It might be a faulty multiport or sand issue.
    Support the site
    May 2013
    North East Ohio
    959
    Quote Originally Posted by JamesW View Post
    some I understand, but not all...problem is the **** media ECOSmarte markets as better than sand (however my PB won't replace so I continue to fight and show him the filter does not work)
    Just replace the sand. Pursue the builder for the cost if you want, but you need to get the issue resolved now.
    Also, check the multiport gasket to make sure that that is not the problem.
    Support the site
