Thread: Sand filter pressure. What should it read?
    May 2011
    London, UK
    48
    Hi All,
    As the topic suggests I'm looking for pointers as to what the correct pressure reading in psi for my sand filter. I assume the lower the better but then I need to know when I need to backwash. I just reconnected the pool yesterday. Should I have put the head on the filter to rinse?
    Cheers
    DK
    CERLAND OCTAGONAL ABOVE GROUND POOL
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    Re: Sand filter pressure. What should it read?
    every install is different. I've been told to determine where yours is (with your current gauge - most of these gauges aren't terribly accurate...and vary from gauge to gauge). Backwash until the sightglass is clear. Then run your system on filter and see where it is.
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    It is indeed different with every set up. Depends on all factors of plumbing, filter, pipe size, returns etc, etc, etc... As mrcarcrazy says, backwash your filter til sight glass is clear, then swap to rinse for about 30 seconds, then to filter. After the pump runs for a minute or two and pressure stabilizes, that's your clean pressure.
    Mine is 14 psi.
    Isolated Spa - 345 Gallons
    38,524
    It should read somewhere between 0 and 40psi. The specific number depends on you setup (pump size, pump speed, filter size, plumbing, number of suction and return lines, number and size of eyeballs, etc).
    You should do a good backwash, maybe even Deep Clean Your Sand Filter, and then see what your clean pressure is. Then backwash when the pressure rises 20-25% over the clean pressure.
    May 2011
    London, UK
    48
    Thanks very much. If you could take a look at my other post regarding a noisy pump that'll be excellent.
