Results 1 to 9 of 9
Thread: Noisy pump. Advice needed please.
    May 2011
    London, UK
    46
    Hi All,
    I have an Espa Silen 50M SP12 pump and it's a little noisy. I have only just started the pool up but don't recall it making this noise. Don't get me wrong, it's not screaming at me. Also, today I connected my vacuum hose to the pool inlet and heard the pump slow down whilst it tried to remove the air in the hose (I did try and fill the hose up with water beforehand but obviously there was still some in there). It returned to normal speed after about 30 seconds or less. I also noticed that the return flow into the pool with the vacuum hose connected was nowhere near as powerful as without but I'm not sure if this is normal anyway.
    Any advice really appreciated.
    DK
    CERLAND OCTAGONAL ABOVE GROUND POOL
    38,271
    Re: Noisy pump. Advice needed please.
    Loud pump usually points to bearing going bad ... you may limp along for awhile. You will either need to have the bearings replaced, or use this as an opportunity to upgrade to a 2-speed motor and likely retain your existing pump.
    You are adding more restriction to the suction line with the hose, so flow will normally be decreased.
    May 2011
    London, UK
    46
    Thanks again. What is a 2-speed motor?
    38,271
    It is a motor with 2 speeds
    Not sure what else to say. On high it would have the same performance as you existing pump. On low speed it would run at half the RPM and move half the water, but only use 1/4 of the amount of electricity. So even if you ran on low for twice as long, you would still save 50% of your running cost.
    May 2011
    London, UK
    46
    Thanks. Was a stupid question now thinking about it but you mentioned I could retain my existing pump. Is this 2 speed thing an add on that controls my pump by reducing the voltage?
    38,271
    You have a pump "wet end" which is what I was saying you could keep and on the back of it the motor is bolted to the pump. You can just replace the electrical motor with a new motor if the wet end is still in good shape.
    The speed selection is not a change in voltage it lowers the amps used ... there are 2 different windings in the 2-speed motors. There there is a simple switch that is used to select the speed (or a timer or automation can be used to switch speeds, but this is not usually needed).
    Maybe these are not as common on that side of the pond?
    May 2011
    London, UK
    46
    Not common at all I'm afraid and the thought or replacing the motor doesn't appeal much. Replacing the bearing was a nightmare (I couldn't replace a circlip)!
    38,271
    Are you thinking that replacing the motor is more work than replacing the entire pump? I guess that depends on how your plumbing is done and your level of experience.
    Replacing the motor is usually removing 4 bolts, spinning off the impeller, and disconnecting the wires. Then just the reverse with a new shaft seal.
    May 2011
    London, UK
    46
    The idea does appeal as the price of electricity in the UK is very high and this pump consumes almost a kW of power an hour. I'm about to post another topic about supplemental heating which I'd love your advice on as well!
