Thread: Main Drain Suction
    NFLJACK's Avatar
    Oct 2013
    Tallahassee, Florida
    2
    Main Drain Suction
    When I dive to the bottom of the pool, I don't feel any suction in the main drain -- nothing. Is something wrong?
    Thanks.
    Jack
    Jack
    33,000 g, IG, , rectangle, 20 ft. x 40 ft., vinyl, Hayward pump and filter (will find out the models), cartridge filter, test kit: Taylor K-1004
    I'm not mad at the pool. I'm mad at the dirt.
    38,537
    Re: Main Drain Suction
    Welcome to TFP!!!
    That is pretty typical ... they are designed that way to prevent entrapment. Of course whether you have flow through there or not is dependent on your plumbing and valving.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Hi, Jack!
    That's pretty typical. Even when I have mine on full, it doesn't feel like anything.
    Do you have a valve to open and close the main drain? If not, do you have two holes in the bottom of the skimmer?
    Jan 2014
    Buckeye AZ
    807
    i just tested my own main drain over this same concern. I thought perhaps the skimmer/main drain ratio valve was installed wrong. But after moving it full one way and putting my hand in the bottom of the skimmer, under the venturi return, and then full the other way and having no suction in the skimmer, it's clear the valve is correct. I also folded up a bouganvillea leaf (no chance I spelled that right) and shoved it through the main drain grid. Got out of the pool and looked in the filter that is just before the pump and the leaf was in there.
    However, I can see a bunch of sediment accumulated in the ring of the main drain; the suction isn't strong enough to actually carry it around into the input ports of the drain. I'll probably have to get a vac attachment down there every once in a while to clean it out.
    10,500 gal IG, Topaz Pebble, auto-level
    Hayward DE filter, 2HP Ecostar VSP, ProLogic PS-4, GVA actuators
    Cal Pools Wave Force Plus (wall return jets plus 2 floor pop-ups), Venturi Skimmer
    Water sheer, 2 wok pots, bubbler stem on the baja step
    ColorLogic Mutlicolor LED lamp. Taylor 2006+speed stir
    NFLJACK's Avatar
    Oct 2013
    2
    Hi, Jack! :wave:
    Thanks for the responses.
    Yes, there is a valve where I can cut off either the skimmer or the main drain. I cut off the skimmer when I felt for the suction on the main drain.
    In the skimmer, there are two holes; however, one is plugged up with some sort of cap.
    Perhaps I'll take a colored leaf and poke it in and see what happens.
    Thanks.
    Jack
    Jack
    Richard320's Avatar
    Jan 2010
    19,074
    Quote Originally Posted by NFLJACK View Post
    Thanks.
    Jack
    Other ways to test it are: swim down with a bottle of food coloring and see if it gets sucked in. Or switch to full main drain suction and set a rubber mat or something over it and see if it starves the pump and the return pressure drops to nothing.
