Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: Brand new salt water pool - HELP!
    May 2014
    Milford, CT
    12
    Our pool is being installed tomorrow and I need some help with how to get my water ready. I've read lots of differing opinions and I'm not sure the proper steps to begin!
    We are in CT, above ground pool, 24 foot round - will be using salt water generator, filter is DE
    What chemicals do I need to start with and does the salt go in first? Or after the PH and stabilizer are balanced?!
    Any help for this pool Newbie would be greatly appreciated! Thank you!!!
    30,419
    Re: Brand new salt water pool - HELP!
    Welcome to the forum.
    We have to have a starting point. Posting a complete set of water test results is the starting point and then we can advise from there.
    38,284
    Welcome to TFP!!!
    As Dave said, you have to start with a full set of test results after the pool is filled ... you already ordered one of the Recommended Test Kits right?
    You CYA will be zero, so you will certainly need to raise that. You will also want to use bleach to maintain the FC levels until your SWG is up and running. Salt can be added at any time.
    How much Pool School have you read? Start with these:
    ABCs of Water Chemistry
    Recommended Pool Chemicals
    How to Chlorinate Your Pool
    Water Balance for SWGs
    May 2014
    Milford, CT
    12
    thanks for the responses! bear with my total ignorance as i figure out this whole "pool thing" LOL
    i understand that once the pool is installed tomorrow and i fill with water, I need to take a full set of tests to determine which chemicals and how much are needed. i guess my question is more basic:
    i understand how the SWG works but unfortunately the salesperson we got the pool from was kind of a ding-dong who told me that salt water pools don't require any chemicals other than the salt (WRONG!); and had absolutely no idea how to answer my questions. so i'm a little confused as to whether i need to add the salt and give the SWG a chance to work it's magic; or do i treat the pool like a standard-chlorine pool and get all my levels where they need to be (including adding chlorine) and THEN add the salt and let the SWG work to maintain the levels. i have found forums that say to start off both ways and i'm not sure which way is recommended. Sounds like Jason you would recommend adding the chlorine/bleach to get levels to where they need to be prior to adding salt?
    38,284
    Treat it like a standard pool to get everything balanced ... add the salt at some point (does not matter when, could even be while you are filling). At least a day after adding the salt and when everything else is balanced, then start to dial in the SWG ... this could be on day 2.
    Fill.
    Test.
    Get the CYA dissolving.
    Get 2ppm of FC in the water.
    Adjust pH if needed.
    Fire up the SWG (a day after adding salt).
    Continue to test and adjust things daily.
    May 2014
    Milford, CT
    12
    THANK YOU! that is exactly what i needed!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    The CYA is no big deal, but wait half an hour between adding bleach and any acid you might need.
    After it's all balanced and circulating, hold Diamond Day. Post #5
    4myBitsy's Avatar
    May 2013
    Milford, CT
    37
    FYI, DeniseP is the friend I was talking about in this thread I posted: http://www.troublefreepool.com/threa...p-for-a-friend. I posted a set of test results on the tap water.
    AG 24' round 52" walls, 12,900 gal
    Proline 22" sand filter, Proline 1hp pump, vinyl liner, Taylor TF-100 test kit, TFPC
    May 2014
    Pasco, WA
    41
    I went through pretty much the exact same situation as you just about a week ago. You can read about it here. There may be some helpful info in there... http://www.troublefreepool.com/showthread.php?t=74542
    18k gal, AG, Sand filter, Aqua Trol SWG, Installed 5/2014
    May 2014
    Milford, CT
    12
    Hi again, pool is up and filled, initial chemicals added - thanks 4myBitsy!! . Here are yesterday's test results
    47" water = 13200 gallons
    FCC 5.5
    CC 0
    TA 60
    PH 6.8 (little low but SWG will raise a bit correct?)
    CYA didn't test - need to wait til Friday but we put in enough to bring to 60
    Am I ready for salt and getting my SWG up and running? Thoughts? Thanks in advance
    You need to manually raise the PH to at least 7.0. Since the PH test reports any level below 6.8 as if it was 6.8, there is no telling just how low your current PH is.
    May 2014
    Milford, CT
    12
    Ok. Thx. Other than that looks good to go salt?
    Yes, everything else you listed is fine.
    May 2014
    Milford, CT
    12
    Hi again,
    Salt is in, SWG running since Sunday night. Here are today's test results....just looking for your expert opinions on how to proceed - I think I could figure it out but want to make sure I'm striving for the correct goals (some confusion between SWG instructions and what I've read on here- tho I trust you guys more
    PH 7.5
    Salt 4200ppm (measured at 4000 on Sunday?!)
    FC 5ppm
    CC 0
    CYA 80ppm
    TA 70ppm
    Calcium 50ppm
    Thoughts? TIA
    38,284
    What do you think?
    My only suggestion is
    May 2014
    Milford, CT
    12
    . I was just worried that the salt is too high
    38,284
    If the SWG is not complaining ... the it should be fine. Is that the reading from the SWG?
    May 2014
    Milford, CT
    12
    SWG is running great, no complaints...it's the result of the salt water testing kit I got (not the strips). Thanks!
    38,284
    My salt drop kit seems to always read about 600ppm higher than what the SWG thinks.
  20. Back To Top    #20
    May 2014
    Milford, CT
    12
    Good to know
