Results 1 to 14 of 14
Thread: Need advice on filter/heater for intex pool
    May 2014
    Lake Forest, IL
    53
    Hello Everyone - So last year in August I picked up an Intex 16' x 48" deep Intex ultra pool for my three kids (Aged 7 and below). I am in the north burbs of chicago and last august was not the warmest weather so the pool was kind of chilly. Took it down for the winter and stored in basement. We had a weekend in the 80s a couple weeks ago so I put it up again and filled using alot of water from the water heater (ran hose into house). Water temp was in high 70s but we have had so cool weather and now the water is in the high 50s. I live in the north burbs near Lake Michigan and so it is usually cooler. I am tired of dealing with the cool water in the pool. I also have alot of large trees in the neighborhood that block alot of the sun.
    I decided I am going to add a heater. Went on craigslist and found a guy that is going to fill in his inground and was selling all his equipment and wanted the buyer to disassemble. I figure I will need new pump. So I grab tools and head over. Here is what i have:
    Hayward H150 heater 3 years old
    Pentair Superflo 1.5 HP pump
    Polaris PB4-60 Booster pump
    Huge Sand filter canister (2' wide by 3' tall)
    Polaris pull vacuum robot
    I paid $600 and the stuff really seems to be in good shape and relatively new. The pool was old but he said he had been replacing stuff as it broke over the last couple years.
    Could I replace my intex pump with the Pentair Superflo and hook that to the heater? Could Ii buy some type of canister heater and splice into the line or would the filter on the pentair superflo be enough?
    Any other thoughts? I am eventually going to either get a bigger Intex or maybe bite the bullet and get an in ground but want to see how it goes for a while.
    Thanks
    Brian
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: Need advice on filter/heater for intex pool
    Welcome to TFP!
    Yes, you can use that pump on your Intex, however you will have a couple of choices:
    You can make adapters to the stock Intex suction and return fittings, or replace them with regular pool fittings like this and this.
    When you start to plumb your pool, you should go: pool suction>pump>filter>heater>return.
    Best bet would be to get a through the wall skimmer, and put in a couple of returns. 1-1/2" PVC pipe will be a good size to use. Be sure to use pool rated ball valves, regular hardware store valves will break after a couple of years.
    May 2014
    Lake Forest, IL
    53
    Thanks Charlie! What kind of filter do you recommend if I go with your first option (pool suction>pump>filter>heater>return)?
    You mentioned putting in a skimmer. If I do that, obviously I would have to cut a hole for the skimmer so would that just be an additional suction point? Would I have to add returns? Also will all of this stuff run on the one pentair super flo?
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Your pentair super flo will handle this and more, easily.
    Most of the Intex pumps (1500gph and higher) are only 1/2hp. You have 3 times that. The largest Intex sand filter only has a 3/4hp motor.
    You could run the skimmer as an additional suction point. In fact, since you have that large pump, it would be a good idea. Yes, you would be cutting a hole in your liner. Many of us have done it already, with no ill effects to the pool. Same for the extra returns.
    There is nothing wrong with using the sand filter you have, it would work great for your pool!
    Next thing you need to start doing is read in Pool School, linked in the upper right corner of every page here, and get yourself a great test kit. No need to rely on pool store testing. With Pool School, you will learn what your pool needs, and the least expensive way to add it.
    The best test kit on the market is the TF-100, from http://TFtestkits.net. Best is to get the XL option and the speedstir. Read up on this in Pool School.
    May 2014
    Lake Forest, IL
    53
    Thanks again. So if I use the two existing holes and don't add a skimmer will the pentair 1.5 superflo pump be too big?
    Also is the filter basket on the superflo pump a filter? Could I put a intex filter in there and use that as filter?
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    You can use the Intex wall fittings, yes. But you will have to make the adapters. Your pump will run a large amount of flow, that is why I'm recommending adding the skimmer and extra returns. Your pump may overdrive the two fittings. There is a way to reduce your pump's output. You can change the impeller to a smaller one, for lower flow rate.
    Why don't you want to use the sand filter you have? It will do a good job of filtering your pool. As large as it is, you probably won't have to backwash but once the entire season.
    That basket in your pump is for catching anything that makes it past any in pool strainers, such as your skimmer or the Intex wall strainer. You can't put a filter cartridge in there, it's not made for that.
    Any plumbing you do to this pool, can be removed and used on your next (larger) pool.
    May 2014
    Lake Forest, IL
    53
    Thanks again Charlie - so if I add a skimmer, how many returns would I need to add?
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Total of two returns would be good.
    Here's a few pics of how I minimized the glue joints on my pool, for bending PVC pipe to fit a round pool:
    I taped a 1200W hair dryer to one end of a 10' length of PVC
    Then as the pipe warmed up, tied it to the support legs
    Added a couple of spacer blocks, because when it cools the pipe has a tendency to "spring back" a little bit
    I let it cool slowly, to minimize the chance of cracking before hooking it up to water.
    Just to make sure it stays in place, I tied it to the base of the supports
    If the flow is still too strong, you could change out the impeller on your pump. I'm sure there are others here that could guide you through that if it is needed. I would wait and see if you like the flow first.
    May 2014
    Lake Forest, IL
    53
    Nice setup and cool idea on bending the pipe.
    I ordered the skimmer you linked above which comes with a return. So I will add the skimmer and the 1 extra return and see how it is. It looks like it isn't very hard to add a skimmer or extra returns. Just nervous about cutting the liner.
    I plan on getting this all up and running this weekend. Once complete I will post some pictures of the setup. I dont really want to lower the flow of the pump because I want the heater to process as much water as possible.....
    Thanks again!!!
    Brian
    May 2014
    Lake Forest, IL
    53
    So I spent a couple days and have the heater, filter and pump installed. Still need to do the skimmer and the secnd return. But it is running smooth!!!!
    Here are a couple pics. When I woke up yesterday the pool temp was 66 degrees. After I turned the heater on the temp went up to 85 degrees in about 4-5 hours or so. I tapped into a 1 inch gas pipe that goes to the meter so I kept the one inch up to the outside and than reduced to 3/4s to connect to heater in the event I need to attach a bigger heater for a bigger pool. I also ran 220 to the new box.
    Thanks for all the help.
    Brian
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Good job on the plumbing. Looks good.
    May 2014
    Lake Forest, IL
    53
    Ok - I have the through wall skimmer and the second return done. Working great. Glad I did it because I still am getting a ton of suction and return with two suctions and two returns so it probably wasn't good for that pump to only have one and one....
    Next question, any recommendations on through wall skimmer vacuums? My next addition.
    By the way, the heater is great, we have used the pool a bunch since getting that in. Now the trouble is getting the kids out....Water is warmer than the air most of the time....
    We will see what my gas bill is but since pool isn't that big cant be too bad...
    Brian
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Did you buy the Hayward thru the wall skimmer? Because they come equipped with a vacuum plate and you can vacuum directly to the skimmer....
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    May 2014
    Lake Forest, IL
    53
    Hey Lace - Yeah I have the Hayward skimmer and it did come with the vacuum plate. I was wondering what vacuum (the hose and vacuum) people use that works best with Hayward skimmer?
    Thanks
    Brian
