Thread: Need help: replace water or not after algea cleanup?
    So long story short, several things went wrong over the winter and I found myself faced with a very green pool. After a few days of slamming the pool, brushing, and running the pump 24x7, it is starting to clear up. My question is whether or not I should replace the water once it is fairly clean. The reason I'm asking is that I saw little organisms in the water when I first uncovered the pool. I'm guessing that all of them were killed by the bleach and that most if not all were filtered out, but still feel a bit queasy knowing that they were in there in the first place. I have a vinyl lining and I've read that it's not good to drain all the way, so wondering if I should or should not risk damage to the lining to replace the water. Any advice would be appreciated. Thanks
    Re: Need help: replace water or not after algea cleanup?
    There is no reason to replace water, unless you really feel strongly about it. "Stuff" gets into the pool all the time. The chlorine kills it and the filter filters it out and you end up with clean water.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Bleach will kill it. Plenty of people have fished drowned rats and squirrels and frogs and snakes out of their pools. Plenty of people have swum in rivers and lakes and survived and who knows what's in them?
    Thanks for the quick replies. I do feel better now.
