Thread: Stuck freeze plug in wall return of above ground pool
    May 2014
    St. Louis
    1
    Opening of pool, and the freeze plug in the wall return of our above ground pool is stuck. I have even drained below return line thinking I could better grib the plug, but no luck. Any suggestions. Can the return line assembly br removed from the wall without causing more problems and the replaced?
    Casey's Avatar
    SW PA
    10,448
    Re: Stuck freeze plug in wall return of above ground pool
    My brother tapped his out with a hammer and screwdriver.
