Results 1 to 7 of 7
Thread: White clumps in my filter sand when changing, anyone know what it is?
    Oct 2010
    michigan
    284
    I have these white clumps in my sand from the filter.
    is it clumped up DE or cellos fiber or maybe those white cotton things in air clumping up? or something else.
    replacing my sand anyways, but would like to know what is causing the white clumps, here is a picture
    15,000 gallon inground fiberglass pool with spa. 350lb Sand filter, 1.5 hp pump, and heater
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    Re: White clumps in my filter sand when changing, anyone know what it is?
    Probably a combination of all the above. What is your normal calcium hardness?-------my next best bet.
    Oct 2010
    michigan
    284
    oh its real soft and mushy,
    normal calcium levels.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Soft and mushy sounds like DE clods. Even DE filters have some stay behind when backwashing, so it wouldn't surprise me if some lingered in your sand. Does it feel slightly gritty when you smash it between your fingers?
    Oct 2010
    michigan
    284
    not gritty at all, if I smoosh it into a cup of water it dissolves into the water. should I worry about this clumping, putting in new sand today.
    Richard320's Avatar
    Jan 2010
    19,074
    Quote Originally Posted by smooth2222 View Post
    No. It could be cellulose. That stuff doesn't feel gritty like DE. Whatever it is, you've removed in.
    Oct 2010
    michigan
    284
    I like using my fiber cellose though, makes the water crystal clear, like a sheet of glass, but I wouldn't want this clumping up to happen again. maybe I need to dissolve it better before I put it into the skimmer?
