Results 1 to 9 of 9
Thread: Missing grout causes water loss?
    Aug 2013
    Hilton Head, SC
    133
    We've been loosing about 200 gallons of water daily. I fill the water about 1/3 up the tiles, mark the level with a piece of blue tape. Over nite the water level drops to just about the bottom of the tiles. I've blocked the skimmer line, the 2 return lines, so the lines are all sealed. I've used Waterweld around the pool light to seal it.
    There are a few places where the tile grout is missing, particularly near the skimmer. I'm about to call and get some estimates to replace the tile grout.
    Suggestions?
    Thx
    4k, IG, Gunnite, Jandy Valve, 1HP Haywood, 2" flow, single 2" line for skimming & vacuum, Pentair FNSP 36 DE w/125 GPM Multiport 50 PSI, TF-100 Test Kit, built 1991, Hilton Head, SC
    Re: Missing grout causes water loss?
    If you don't refill right away the water will drain down to the height of the leak. If the leak is fairly high, i.e. a grout problem, you can let the pool drain a little and then it will stop going down at the height of the leak. That will give you a major hint about where to look for problems.
    May 2014
    South Carolina
    17
    I can private message you my beaufort area partners information if you would like?
    210k gallon pool, IG Plaster, (2) marathon 7.5 hp motors, (6) Triton sand filters, Test Kit Guardex 4-in-1 Plus DPD & Taylor K-2006, Baby pool 6in deep round with stand alone sand filter.
    Aug 2013
    Hilton Head, SC
    133
    Yes, please!
    I'm in Bluffton, just off the island....
    thx
    ed
    Aug 2013
    Hilton Head, SC
    133
    Yes, that's what I've done...the water stops leaking just as it gets to the bottom of the tiles. So, I don't think it's leaking from the bottom drains.
    ed
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Perhaps a skimmer leak? Missing grout should not cause you to lose water...you could chip off the tiles entirely and the shell would still hold it in.
    Aug 2013
    Hilton Head, SC
    133
    Hmm somewhere I still have a red dye needle tester. I'll poke around see if I can find it....
    Thx!
    Aug 2013
    Hilton Head, SC
    133
    Benjamin, please do.
    Thx
    Ed
    Aug 2013
    Hilton Head, SC
    133
    Ok been watching this for a week now. I fill the pool to 7/8" up the tile. Run the pump for a couple of hours, let it sit over nite. Within 48 hrs, the water level drops to 1/2" above the tile and holds there. Ground off to the side of the skimmer gets very wet, call it "mushy".
    Weir is missing.
    Can a skimmer be replaced? Do I know it's the skimmer? There are no leaks around the pumping station. I closed off the skimmer line and returns for a couple of days and still lost the water.
    Suggestions?
    Still waiting for local pool service to perform pressure test on lines. Is this something I can do myself?
