Thread: filter trap not holding water
    Apr 2014
    Upper Chichester, Pa
    60
    My filter trap is not holding water. Every time I have to start up the filter I have to open the trap and let water in to start the filter anyone know why??? Now this morning the o ring broke and water is everywhere and I was rushing out to buy a new o ring...not a good pool morning. Am I doing something wrong? I am a new pool owner and have read all the manuals and thought I understood the trap should always have water in it to run the filter please help
    Sharkline Reprieve 21' x 52" Round Above Ground Swimming Pool, Waterway 520-5220-6S ClearWater 19in. Sand Filter Above Ground Pool System with Hi-Flo Single Speed Pump, using BBB method and TF-100 kit
    30,421
    Re: filter trap not holding water
    Are you referring to the pump strainer basket? It's got the clear, removable lid on the front of the pump.
    This article in Pool School may help...
    http://www.troublefreepool.com/conte...pool-equipment
    Apr 2014
    60
    yes the plastic lid
    38,305
    If you pump is below the water level (signature says it is an AG pool), then it should stay full of water ... no priming required. Does the pump empty when you turn the motor on? Or is it emptying while the motor is off?
    Apr 2014
    60
    it emptys when its off. but we did fig out the problem apparently because we didn't lube the o ring it wasn't sitting in there the right way and we had a leak thanks that was an all day trouble shooting process but I did finally fig it out
