Results 1 to 7 of 7
Thread: Is 52" the deepest AGP available?
    Jul 2008
    Little Rock, AR
    44
    Does anyone make an AGP that is deeper/taller than 52"?
    I know there are pools with liners that can stretch to make a deep end by digging out the ground but I would think there is some vendor that makes a pool taller than 52".
    If no one does, why? Is it just physics and cost prohibitive to make it strong enough?
    Bill
    16' Intex Metal Frame AGP with vinyl liner, ~5100 Gal, 637R 1000 GPH & 633 2500 GPH pumps w/cartridge filters, Intex SWCG
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Is 52" the deepest AGP available?
    I thought I saw a posting on here about 54 inch walls? I have 52 and so does my friend but his pool walls look taller than mine. Maybe the new 52 are really 54 and the old 52 are really 48?
    Jul 2008
    Little Rock, AR
    44
    Thanks for the reply but 52" or 54" would be all about the same. I'm thinking of a 60" to 72" pool and wondering if anyone makes something taller than the usual 4' pool.
    Guest
    This may not help -- mine is only about 3' above ground but has a deep end that is 8' deep. It's a Wilke.
    Jul 2008
    Little Rock, AR
    44
    Not quite what I'm looking for but thanks. I'm looking for a pool that has walls that are higher than 52".
    I'm looking for my next pool and want it to be 45-55 feet in length but deep enough to do flip turns for laps. My property is on a ridge and is nothing but rock (yard work is a breeze). It takes a trackhoe with a jackhammer to carve out holes and at $250/hr for the hammer and $120/hr for a regular trackhoe to scoop out the debris, it gets expensive real quick. If I can find an AGP which is at least 5' deep, that would fit the bill but just haven't found it using google yet. Maybe nobody makes one but will keep looking.
    Bill
    Guest
    I'm an old racer -- I can do flip turns in 3' as lots of pools I've used are pretty shallow on at least one end. I'm envious of the length, though!
    Have you ever tried one of those Endless pools? That will be something I'll investigate when this one goes.
    Sue
    Jul 2008
    Little Rock, AR
    44
    I'm 6'-6" so I need a full 4' of water to do easy flips but the more the better.
    I've seen the endless pools and they look nice but I'd rather have a larger pool for when friends and family come over. I've not had my Intex very long but I can already see that I want a larger, more permanent pool so I'll spend the time to do my research.
    Bill
