Thread: New Test Results
    Road scholar's Avatar
    May 2014
    Bowie, Maryland
    41
    New Test Results
    The K-2006 arrived over the weekend while I was out. My wife, who is not a chemist, tested and came up with the following results:
    PH 7.4
    Alkalinity 40
    Calcium 70
    CF and CC n/a. Pool was just filled from complete drain
    CYA 10, she did not test but this result was from the pool store
    What should I add?
    60' x 20' L-shape, 23K gal, NSW, IG Plaster, built spring 2002, 3 HP Inteliflo pump, Cartridge filter, gas heater, swim lane, volleyball net, Dolphin A30i robot.
    Oct 2013
    Chapin, SC
    1,141
    Re: New Test Results
    First, get your own full set of test resuts and post them here, if your cya is really 10 you may not see the black dot disappear. Buy some cya: This is probably the best buy for cya: http://www.walmart.com/ip/My-Salt-Po....5-lb/34752155 you may have to order it site to store. (Free shipping). Put the amount needed in an old athletic sock and hang it in front of a return: https://www.dropbox.com/s/ndmcbhx7vm...2011.52.39.jpg also, put in enough bleach to get your FC up to 3-5 ppm you can find 8.25% great value at walmart reasonably too.
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
