Thread: help. aquabot turbo wont run
    lindaspoolboy's Avatar
    north NJ
    23
    I hope somebody can help.
    I can tell power gets to my aquabot turbo (because i see the push of water out of its top), and then WITHIN A SECOND i hear a click in the control box, and it stops.
    I can repeat this over and over.
    Thanks in Advance,
    Max
    29,000 gallon vinyl IG, Hayward 1.5hp Pump, DE Filter.
    Jun 2008
    Scottsdale, AZ
    37
    Re: help. aquabot turbo wont run
    Common problem with them. You need a new motor and it's usually cheaper to just get a new unit.
    Gary
    18 x 38 28800 gals gunite inground;Purex Triton High Rate Sand Filter;1 HP 2 Speed Hayward Tristar Pump; Raypak Heater
    Aquabot Bravo; Goldline Aqua Logic Controller/SWG
    north NJ
    23
    OK, thanks for reply Gary.
    I had something similar happen a few years ago, and it was a bad power supply. They repaired it for about 75 bucks and it was good to go for several more years. I sold it 2 years ago. If that's what the problem is, it would be worthwhile to have it fixed. If it's the motor, then, as Gary says, you may as well get a new unit. Good luck.
    Tom
    In gound vinyl L, ~41,000 gallons, Pentair Clean and Clear Plus 420 cartridge filtter, Pentair 2 speed WhisperFlo pump
    north NJ
    23
    Thanks Tom.
    It mysteriously began working again when i tried it later that day.
    Jun 2008
    Scottsdale, AZ
    37
    That sounds like a familiar symptom. As Tom indicated it could just be the power supply but either that or the motor is dying.....sooner than later I'm sorry to say. I've had several Aquabots (at least 4 now) over the last 14 years. The newer units come with four year warranties now so that helps. Previously I could count on replacing about every 3 years. The other thing that is important is that you check the belts but I don't think they are your problem with the symptoms you describe.
    Gary
