Results 1 to 8 of 8
Thread: New member
    Hey all. I was turned on to this site by a neighbor. I just started going through the Pool School.
    The one thing that sold my kids on our current home was the pool, an 18ft above ground (we have a 24ft now.) I used one of the local pool stores for testing and chemicals. I never walked out of that store without spending $150 on chemicals and three pages of instructions. One summer the pool turned green. After hundreds of dollars they finally told me, "We don't know what's wrong." I decided to drain the pool to scrub it out good. When drained, I noticed all these little 'pit marks' on the bottom. Someone told me of a Mom&Pop lawn & garden store that also does some pool work. They told me not to use the powder stuff. They like the liquid stuff. Things were good for the last five years. Well, they went out of business so this year back to the first store. You guessed it...$$$$$$$. They don't like the liquid so I used the powdered chlorine again. I spent the next seven days brushing the pool four or five times a day to get all that **** dissolved. The pool turned green and the store tells me I must be doing it wrong. Another friend told me to go to a different store. The people, there, and I got along fabuously And now I'm here. My neighbor told me that she has disposed of all of the $$$ chemicals and will start using your BBB method.
    Well, back to school.
    Thanks for letting me blow off some steam
    JimB
    woops. upon previewing this, I see one to many zeros my pool is actually 13,500gal
    JimB
    on the Northcoast of the U.S.A.
    24ft AG-13,500 gal-Hayward S-166T high rate sand filter-pump is SplashPak Hp 1spl (whatever that means)-TF100 test kit
    meatloaf's Avatar
    Feb 2008
    Gilbert AZ
    373
    Re: New member
    Welcome to TFP
    There is a lot of great information on this site and plenty of great people to help you out.
    Make sure you have a GOOD test kit, check-out the pool school and use the pool calculator.
    Get accurate test results! Accuracy is very important! Also be patient, give the chemicals time to do their job and you should be fine. Keep surfin the site and enjoy. One more thing, check out the BBB method.
    This site is the BEST!
    Good Luck!
    My pool is a 10,500 gallon (420 Sq Ft ) kidney shape. STA-RITE HRPB30, Sand filter 30" 98 GPM, 1 HP Maxi-Glas 2 pump, BBB Method, Taylor K-2005 test kit, 50 Watt 12V low-voltage pond light illuminates the pool at night for a nice soft glow.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: New member
    Welcome Jim! You found the right place.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: New member
    Hi JimB,
    Yep, you've found the right place!
    Welcome to the forum
    You're done SLAMing when:
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: New member
    Jim, welcome to TFP!!
    One problem, you're gonna have to decide what you're gonna do with all the $$$ you won't be spending on the pool
    Luv& Luk
    -Ted
    Re: New member
    There's always some new gadget for the motorcycles. Or some new safety equipment, i.e. gloves, helmet, jacket etc.
    JimB
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: New member
    Welcome!
    Re: New member
    welcome!
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
