Thread: Just got test kit after SLAM failure
    Jun 2013
    Charleston, SC
    2
    FC 0
    PH 7.2
    TA 70
    CH 130
    CYA 30? (black dot goes away when tube is filled to top)
    I just added 100oz of borax to bring Ph up to 7.6
    I started researching this site at the end of pool season last year after having a hard time with my pool for 3 years prior. I ended up throwing my hands in the air and ignoring my pool all fall and winter. We had two ice storms here this winter, which we normally don't have at all, and we had huge branches and smaller branches from our pine tress in the pool. Took me 2 weeks, 3 hours a day just to clear out debris from pool.
    I tried SLAMing my pool 2-3 weeks ago without a test kit. It made it not a swamp anymore but is still extremely cloudy. I stopped with chlorine/bleach until I got my test kit, which I received today. Above are my results.
    What I want to know is what should I work on first. My calcium hardness? Should I SLAM the pool again before adding stabilizer? Just need a little direction before I try again.
    I'm including pictures of pre-SLAM and after(which is from tonight)
    35k gal, IG plaster, 1 HP Heyward pump, sand filter
    30,421
    Re: Just got test kit after SLAM failure
    Ignore your CH for now.
    Looks to me like you can start the SLAM anytime. Use 30 as your CYA value so you should be bringing the chlorine up to about 12 ppm each time you test.
    Make sure your filter is clean and working well before you start. Your water looks pretty decent already so filtration will be very important to get it completely sparkling.
    Review that SLAM article in Pool School and get started!!! We'll all help if you need it!
    After the SLAM is complete, you can adjust CH.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Welcome!
    You're ready to rock-n-roll, your low CYa level is ideal for the SLAm. I wouldn't have even delayed to mess with the pH, myself. You've waited long enough for a showcase pool, and the big holiday weekend is coming! Jugs away!
    Jun 2013
    Charleston, SC
    2
    Should I raise the cya after SLAMing?
    30,421
    Yes. How much you raise it depends on your chlorination method. Just
    SLAM for now and focus on getting that completed.
