Results 1 to 16 of 16
Thread: Do we need a pad under steps in AG?
    Do we need to be concerned about liner wear under the steps in our above ground pool? Should we put some kind of pad or cushion under it?
    Ken & Kris Parker
    9,200 AG, 15X26 oval
    2.5 HP pump, cartridge filter
    AquaRite SWG
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Re: Do we need a pad under steps in AG?
    What kind of steps do you have?
    Les
    Don't have a pool right now. Just sharing what I have learned over the years!
    Helpful Links:
    Pool School,Pool Calculator,Cl/CYA Shock Chart,TF Test Kit
    Doing BBB and loving it!
    We have the smart step system by Main Access. We have a deck adjacent to the pool, so we are not using the back removable ladder.
    Ken & Kris Parker
    AquaRite SWG
    Jul 2007
    Northern NJ
    299
    Most of us do to protect the liner from tears. You don't have to purchase a pad, though. Go to the plumbing section of HD or Lowes and have them cut you a piece of the rubber liner used to line showers. Should cost you less than $10.
    Nicole
    21' AGP (10,400g)
    Hayward PowerFlo Matrix dual-speed 1HP pump, 75 sq ft Waterway cartridge filter
    4G Liquidator, Aquabot POOL ROVER S2-40
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    My experience.. our first ladder didn't lie reach the pool floor, the way it was attached to the deck held it in place. When that ladder broke, we replaced with our current model for $79 and you get what you pay for Anyway, this one rests on the pool floor. I don't have a pad, but I did notice (thankfully before it got too bad) some algae trying to take hold under the ladder. I'm able to move it abit so I brush at that spot whenever I'm in the pool. My point is, whatever you decide to do, consider water circulation and ease of removal for weekly brushing so you don't get algae under there.
    Jul 2007
    Va.
    76
    I got a piece of shower stall liner from Home Depot under mine.
    15x30x54 AGP, Hayward 1hp 2 spd pump, cartridge filter, Royal Entrance steps,Pool Rover Jr
    thanks everybody! i'll check out the shower liner at HD/Lowe's.
    Ken & Kris Parker
    AquaRite SWG
    Cassiopeia's Avatar
    Jun 2008
    Tampa Bay FL
    46
    And thanks for starting this thread, what a great question and good responses! I will check out the liners also. Good to know!
    15' ROUND, 52" AG
    Newbie at pool ownership!
    Jul 2007
    Summerton, SC
    39
    Any thoughts on the size? Just the size of the ladder or steps footprint? For a ladder, maybe something like 12" X 30" or is that too big?
    Jim
    24' X 52" AGP (13,500 gal)
    Pentair Dynamo 1HP with SD-40 filter
    TF-100 test kit
    BBB and loving it
    Jul 2007
    Northern NJ
    299
    My steps are 2ft wide and I made the mistake of having it cut 2ft wide. It wasn't wide enough to go under the feet on the stairs on both sides. I would suggest measuring the width of the stairs/ladder and giving yourself another 6"-12".
    Nicole
    21' AGP (10,400g)
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    I thought I remember seeing where someone had taken a pair of flip-flops and placed one under each post of their AG pool ladder as pads. It was cheap, effective, and fairly novel. As long as you can handle the "hey, yer ladder is growing feet" jokes.
    Beanie's Avatar
    Jun 2008
    North Carolina
    44
    We have wedding cake stairs in our AG pool and I don't have a pad under mine. I also move mine everytime I vacuum the pool because I don't want any build up underneath it. I have never had a problem moving my stairs and find them quite easy to move in the water.
    ~*Tricia*~
    ~Red Sox Fan 4 Life~ *Go Jacoby*
    My Pool
    24' Round AG Pool...52" high...13,500 gallons
    Hayward 1.5 HP Power Flo Matrix Pump and Sand Filter...BBB Method
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    Anything you can do to protect your liner from wear will extend the life of liner and give you some piece of mind. We have the shower stall liner (plumbers mat) - it is cut so that there is 6-8" on each side
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
    Cherie's Avatar
    Jul 2008
    Wylie, Texas
    506
    So what keeps the liner from slipping out from under the steps when the pool is being played in and water is wildly splashing about? Last year, we used the steps that came with the pool, along with the cheap little pad. The pad wouldn't stay in place, so we finally just took it out. This year, we're about to put in our wedding cake steps and want to make sure we don't ruin our liner, since a replacement would not be easy...or cheap, given that our pool is buried. We'll go to HD and check out the matt mentioned. Also, what are the chances that algae will start under the overlap part of the pad, if you get it bigger than the pool steps? We hope to have enough weights in the steps to hold it in place, but it seems the overlap pad under the steps would be open for algae.
    Or am I fretting too much over a little issue??
    32x16 buried Doughboy, 4' shallow - 7' deep
    Pentair Dynamo 1 hp, 2-speed - Pentair 150# SD40 w/zeolite (75#)
    One skimmer/two returns/Aquabot Turbo T2
    AnnaK's Avatar
    Jul 2007
    Eastern Pennsylvania
    1,134
    We have wedding cake steps. In their first season they dug indentations into the sand under the pool liner. In the second season we cut pads from an old yoga mat and put them under the front of the steps where most of the pressure is.
    The result was algae growth on and under the mats. I got tired of taking them out and scrubbing them and we no longer use them.
    AnnaK
    12,500 gal AGP, Hayward sand filter, Pentair 2-speed pump, timer.
    Please visit our Pool Issues pages for information about step weights, managing the solar cover, and PoolSkim.
    Jul 2012
    Pittsburgh, PA
    15
    I'm contemplating the same thing knkp. I have the larger wedding cake steps for my in ground pool. Could someone who's done it post a link to item they bought from Home Depot so I know I'm getting the right thing? Also, I bought my steps on Craigslist and the guy said he had to put bricks in them to keep them from moving around. Does anyone do that?
    Eric N - Pittsburgh, PA
    16000 gallon rectangular in-ground (14' x 28', 3.5' - 7.5')
    DE Filter
    Vinyl Liner
