Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: So here is where I am
    Jul 2013
    Gilbert, Az
    116
    Last summer I couldnt get my pool right... I miscalculated getting the CYA up and ended up with a cya of 100 with an algae bloom... very short swimming season here (at least in my pool). At the start of getting the pool ready this year we mostly drained and refilled... getting the cya down to 0 still had algae in the pool. Last summer everytime I would add DE to the skimmer it would blow back into the pool... Ended up with probably 20lbs of DE in the bottom of my pool. This year I opened up my filter an half my grids were broken... ordered new ones and began slamming my pool using the pump mainly for circulating the water. When the new grids came in I replaced them and primed my filter. Then I started vacuuming up everything on the bottom... By this point the water was clear but the bottom was the problem. I had to backwash the filter several times in my 2 hour vacuuming session then opened up the filter and cleaned the grids. They were so caked with DE at this point (within 24 hours of replacing the grids). So not I had a clear pool with only rocks in the bottom (leaf rake broke so i cant scoop them out and the 2 times in 2 days that the kids have been in the pool they havent gotten the rocks out). FC is holding steady occasionally dropping .5 ppm below min.. I added CYA enough to go to 30 but only registering at between 20-25. I dont have the full tf100 kit yet... What I do have is the chlorine test from that kit (bought on its own) a 5way test, and a CYA test kit.
    Current results
    FC-6.5
    PH-8.2 (gone up since ive been working on everything)
    TA-140 (I know I need to drop this)
    CYA-~20-30
    unfortunately the day after I cleaned out my filter my pump motor died. so the only circulation anything is getting is brushing and kids playing in the pool. The landlord has a call in about the pump so I am just having to wait on it. I am only having to add about .5 gallon of liquid chlorine a day (my non pushy pool store sells 2 bottles of 10% for less than $7... with regular specials of $4.99 for the same thing... i stocked up) is the brush and kids eough to work on my PH/TA issue or should I just keep the chlorine stable till my pump is fixed?
    12k - free form - plaster- Nautilus fns48 DE filter- centurion 1hp (so quiet)- In floor cleaning system with Jandy Caretaker - TF-50 and 5 in 1 test kit, Phoenix, Az
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,065
    Re: So here is where I am
    Welcome!
    It actually sounds like you understand the TFPC way pretty darn good!
    Test TA so you can get an accurate acid dose out of poolmath, but don't even think about aggressively lowering it until the pump is running again.
    You will always need to maintain pH and FC if you want anyone in the pool. Use the brush to get things dispersed. Add whatever and make a quick lap around the pool. The kids will do the rest of the mixing for you.
    Jul 2013
    Gilbert, Az
    116
    Well pool guy is here installing a new pool pump. .. will have to update my signature with the new info
    Jul 2013
    Gilbert, Az
    116
    New pool pump installed... just in time my PH keeps going up... about to dump half a gallon of acid in and get the ph and ta lowered... PH is reading at 8.4 and TA is at 180... My chlorine is a little on the lower side right now should i worry about PH first or chlorine first? How long should I wait till I start aerating it after adding the acid?
    JesseWV's Avatar
    Apr 2011
    North Central WV
    526
    Adjust the pH first, let it circulate 30 minutes. Then raise FC.
    Also, your TA comes down when you add the acid. Aerating increases the pH without increasing TA.
    It's also worth mentioning that your pH could be higher than 8.4. I would retest about an hour after your first acid addition to see if you need more.
    16k gal, 28'x3.5', Vinyl A/G, 1hp Pentair Dynamo 2-speed Pump, Hayward S160T Sand Filter, Intermatic HB800RCL Digital Timer, Intex 8110 SWG, TF-100 Test Kit, SpeedStir Author: Jesse's Graphical Pool Testing Log
    Jul 2013
    Gilbert, Az
    116
    Yeah, main thing i am working on is the ta.. once i get that down i know i wont have my PH rising as fast or as bad
    Should star tunning the aerator immediately?
    JesseWV's Avatar
    Apr 2011
    North Central WV
    526
    Start aerating as soon as you lower the pH to 7.0-7.2
    Also, I just noticed you have a plaster surface, you really need a CH test!
    38,520
    TA is the last priority. Maintain the FC and the pH in range.
    Jul 2013
    Gilbert, Az
    116
    Quote Originally Posted by JesseWV View Post
    Well coming in from an almost complete drain and not adding anything except liquid bleach CH SHOULD be ok right now. As soon as i can affor the full tf100 test kit i will get that info... If the CH is already high just from my tap water then I dont think I can do much for it. I do have calcium staining from last year. the PH in this pool has always been very difficult to maintain. So I will eventually have to see what can be done about that.
    Oh and only about 2 weeks into that drain/refill
    Jul 2013
    Gilbert, Az
    116
    I ordered the tf50 kit (since i already have a kit for testing PH including acid demand) but it hasnt come in yet. Its been 3 or 4 days since i ordered it... Right now my pool is at
    FC- 1.5 (i forgot to add my chlorine last night so added this morning after I tested)
    CC- 0
    PH- 7.2
    TA- 110
    CYA- less than 20 but more than 0... will need to grab some more today
    Need to get some more acid to finish lowering the TA
    [IMG][/IMG]
    Jul 2013
    Gilbert, Az
    116
    Now that I have most everything taken care of... What can I do about the calcium scaling. I know its scaling because the plastic rim around my pool light was covered with it and I was able to scrape it off. Last year the PH was ALWAYS high and the water here is hard. My tf kit hasnt come in yet so i cant test my CH yet... but it shouldnt be too bad right now... 3 weeks in from a drain and refill and nothing has been added that has any calcium in it...
    30,432
    The best way to control your calcium scale is control your pH. Bring it down and KEEP IT DOWN into the lower 7's with muriatic acid...regardless of how much it takes.
    If necessary control your TA with baking soda (to bring it up)
    Jul 2013
    Gilbert, Az
    116
    Ta is on the high side still but I got it down to 120
    Jul 2013
    Gilbert, Az
    116
    Got my tf-50 kit today so here are current readings
    FC- 4.5
    CC- .5
    PH- 7.8
    TA- 110
    CH- 780
    CYA- 25
    still working on leveling PH... then i need to do something about the CH... gonna have to test my tap water and see what it is... i know its pretty hard here
    Jul 2013
    Gilbert, Az
    116
    Tap water has a CH of 300
    Richard320's Avatar
    Jan 2010
    19,065
    Quote Originally Posted by Nuvene View Post
    Ouch!
    One tip: use a 10 ml sample as described here: Post 7 notes.
    Where your CH is, it doesn't really matter if you read 775, 780, or 800.
    Also, are you using a speedstir? My high CH readings dropped about 200 ppm when I started using it. Mixing is super important for the CH test.
    Jul 2013
    Gilbert, Az
    116
    Ouch!
    no speed stir and yes using the 10 ml sample
    Jul 2013
    Gilbert, Az
    116
    So pool looks great but my ph just some stay down I'm having go add half a gallon of acid every other day... my ta dropped from 180 to 50 now back up to 80 refilling from evaporation. What can i do go keep my ph in line... I had half as much acid as chlorine
    Casey's Avatar
    SW PA
    10,457
    How old is the plaster? You have to just keep on it with the MA, even if it's every other day or so.
  20. Back To Top    #20
    Jul 2013
    Gilbert, Az
    116
    Pool was installed in 2007... I have a lot of calcium scaling as it is so i can't get that taken care of as long as the ph keeps saying high....
