Thread: !!!! Filter Emergency!!!!!
    So after vacuuming a few times and finding junk in the pool the next morning I opened up the filter and removed the sand (Hayward GM-142 sand filter 50#) and find that the stand pipe is cracked 90% of the way around at the base. I can't get a new pipe, I would have to get the whole tank at 250.00 or more. I need advice fast on what to go with for a new filter; cartridge, DE, brand etc... . The pump is a single speed 1HP Hayward. HELP!!!
    Wayne
    own intex 15' above ground metal frame pool
    cartridge filter pump model 637 800gph
    Re: !!!! Filter Emergency!!!!!
    Hi, Wayne, welcome to TFP.
    A question like that is liable to get you as many answers as there are members here! Everyone has their preference on what type of filter is best!
    I am not an equipment guru... I am sure someone who knows more than me will chime in shortly!
    8200 gallon 20' x 48" round vinyl frame pool, manually chlorinated with 10% liquid, salt added to ~2000, 12" sand filter, 1600gph pump, TF100 test kit
    Jul 2007
    Sahuarita, AZ
    278
    Some details on your pool would definitely be useful... size, construction, etc... where you live... do you have lots of trees nearby...
    My Pool:
    12K gal IG gunite with 7' raised spa, gunite waterfall, PebbleTec Caribbean Blue finish, solar heating & in-floor cleaning system
    Equipment: Sta-Rite 300' Cartridge Filter, Intellichlor IC20 SWCG, Sta-Rite 400k BTU heater, Intelliflow 4x160 main pump & Sta-Rite 3/4 hp waterfall pump, EasyTouch controlls w/ wireless controller, TF-100 Test Kit w/ salt test.
    Heheh, I realized that I never gave the pool size in the original post. Anyhoo, the emergency is over. I was able to go to Lowe's and get a schedule 40 pipe and a fenco sleeve and we are running again for 5 bucks
    Sorry for panicking and thank you for the fast responses. This one's for you
    Wayne
