Results 1 to 16 of 16
Thread: Problems with spa jets and sand in spa
    azsunshine2014's Avatar
    May 2014
    Scottsdale, AZ
    14
    Hi everyone, First time poster. I did some searching but kind of got lost in the process so thought I'd start my own thread with our problems.
    We totally remodeled the pool this spring. New pebbletec, new variable speed pump, new sand in the filter and new light.
    Problem 1:
    After tech installed the new pump, replaced the sand and turned it all on, we had sand flowing into the pool/spa. Turns out it was a broken manifold in the filter which we then had replaced. Now there is still a little sand that keeps getting into the spa. We've cleaned and cleaned and cleaned, but it keeps coming back. We're down from probably 50 pounds to a couple of cups. But it's still enough to gather and make using the spa feel like it's confused as to whether it's a spa or beach!
    Question: Could it be that sand is still in the lines? How long should it take for all the lines to be cleared of sand "if" all is in good working order?
    Problem 2:
    We have lost all jet action in the spa except for 1 jet. I think we have about 6 total. I can put my finger in the jet and feel a little swirling water but spa water is basically still. When we turn on the blower, water is blowing up hard and splashes out over the top,but yet if you put your hand in front of the jet you feel nothing.
    Question: It seems there is no directional on the spa jets. Is that the reason? I read about "air-lock" but it seems that applies to above ground spas. Any other ideas on how to fix?
    Thanks!
    ***Original owners of 18 year old 8500 gallon inground Pebbletec pool/spa with spillway into pool
    ***Saltwater system ***Hayward sand filter
    ***PebbleTec completely replaced April 2014 Hayward EcoStar Variable speed pump (IS3401VSP) installed May 2014 New sand - May 2014
    Re: Problems with spa jets and sand in spa
    Welcome to TFP!
    1) Normally it should only take an hour or two with the pump running to flush out any sand. Still, if sand is only going into the spa, and not into the pool, odds are that the filter is fine and this is somehow connected to the spa jet issue.
    2) You should remove the spa jet nozzles and flush out the system by running in spa mode for an hour or two with the nozzles out. The jets often require a recessed wrench, kind of like a spark plug wrench to take out, though that varies somewhat by brand. In any case, that is probably the only way to really get everything out of the spa plumbing.
    May 2014
    Scottsdale, AZ
    14
    Thanks!
    Hubby said it sounds like you are thinking we have small nozzles but we don't have those. We have big openings in the spa jets that rotate. Maybe like an inch wide?
    May 2014
    Scottsdale, AZ
    14
    A picture is worth a thousand words. So...
    Attachment 29417
    May 2014
    Scottsdale, AZ
    14
    Anyone have any other ideas? Do we need to change out the eyeball things?
    mas985's Avatar
    Pleasanton, CA
    11,742
    The spa jet nozzles are deep inside the wall of the spa. You cannot see them from the outside unless you empty the spa and look directly into the hole. You need a long 9/16" socket wrench to remove them and most look like this:
    Mark
    May 2014
    Scottsdale, AZ
    14
    Thanks! I"ll lower the water level and see what we've got. How far into the wall are they usually?
    mas985's Avatar
    Pleasanton, CA
    11,742
    They can be 1" on up but probably not more than about 9". Removing them makes it easier to flush out the lines. If you continue to get sand after that, then there could still be an issue with the filter.
    Mark
    May 2014
    Scottsdale, AZ
    14
    Still working on this problem. We used a long 9/16 socket wrench and that didn't work. It just hit a wall and there was nothing for it to grab/go around. We're just enjoying the pool this weekend and will drain it next weekend and try again.
    mas985's Avatar
    Pleasanton, CA
    11,742
    You might just try running the spa. If it was residual sand, it should clear over time.
    Mark
    May 2014
    Scottsdale, AZ
    14
    we did that. Ran the spa for a couple of hours and the blower for about 1 hour. The bigger issue is jetted water coming out of 1 jet out of 5. The other 4 have nothing.
    I read in another thread to lower the water and turn the spa on. Water should flow out of the jets. Same result. Water comes out of one jet and nothing out of the others.
    mas985's Avatar
    Pleasanton, CA
    11,742
    Yea, that is probably a blockage of some sort and usually the only way to clear that is by removing the nozzles.
    Mark
    May 2014
    Scottsdale, AZ
    14
    We're trying, just have not been able to remove the nozzles. Need to drain the spa completely so we can actually see in them instead of just trying to put a 9/16 socket wrench in and feeling our way.
    May 2014
    Scottsdale, AZ
    14
    Hi everyone!
    Yea....finally got the spa fixed! All is good.
    Hubby had full knee replacement on June 5th so that sort of put a wrench in our life for awhile.
    I finally was able to drain the spa and with a flashlight saw the nozzles you said we had and every one had a strange piece of plastic in them. One also had lots of sand and debris as well. We can't figure out what there little pieces of plastic. They are obviously broken from something but one was in each nozzle. Got the 9/16th socket wrench and removed all the nozzles. Turned on the spa and water came out of each of them!!! Yea!!!
    Then I vacuumed all the sand out of the spa, refilled it and we have a spa again!
    Thank you all so much for your suggestions and help!
    mas985's Avatar
    Pleasanton, CA
    11,742
    Quote Originally Posted by azsunshine2014 View Post
    Could be that.
    But glad you got it fixed.
    Mark
    May 2014
    Scottsdale, AZ
    14
    Not sure about the manifold. It was black and cracked but no visible pieces missing nor did we see any white parts on the manifold.
    But, I can't tell you how happy I am that it's fixed!!! Without being told here about the nozzles, I would never have figured it out!
