Thread: Couple of questions
    daddycreswell's Avatar
    Jul 2013
    Lebanon TN
    130
    Couple of questions
    I needed a new pressure gauge, so I picked up one at HD, it's a 100 psi one. It's the only one they had, anyway my other was was busted, I can't remember what it read when it was clean and dirty. The new one reads about 12 psi, so I am guessing it it clean.
    My other question is for anyone with a compupool SWG, The system is reading NO WATER, can anyone explain this to me? It has water in the SWG cell.
    Thanks for the help.
    16 x 32 18,000 gallon vinyl liner inground pool, Compupool SWG, 1.0HP Pentair pump, sand filter.
    Re: Couple of questions
    Your SWG is probably trying to say that there isn't enough water flowing through the cell for normal operation. Clean out the skimmer(s), pump strainer basket, and clean/backwash the filter and see if the error goes away.
    Jul 2013
    Lebanon TN
    130
    Quote Originally Posted by JasonLion View Post
    I've done all that, and the cell is full. I don't know what else to do. I've even cut it off and restart to see if it would reset itself but no luck.
    UN1017's Avatar
    May 2012
    Sacramento, CA
    288
    How old is your SWG?
    Nevermind. Found it here.
    I'm not confident that your SWG has much left to give.
    15'x30' IG - Roman-style - 14K - Pebble Fina Classico
    Filter: Jandy CL460 Pump: Jandy Stealth SHPF1.5 SWG: Jandy AquaPure 1400 Cleaner: Jandy RayVac Test Kit: TF-100 w/SpeedStir
    Chlorine/CYA Chart----Extended Test Kit Directions----SLAM
    Jul 2013
    Lebanon TN
    130
    Quote Originally Posted by UN1017 View Post
    That's what I'm wondering, but I can't get anyone to tell me for sure. I now it is generating during it's scheduled times, I can see the bubbles in the cell. I've never been a big fan of the Compupool but don't want to drop a grand on a Hayward Aqua system.
    UN1017's Avatar
    May 2012
    Sacramento, CA
    288
    Okay daddyc...
    I just familiarized myself with your situation from the thread you started last week.
    You have many variables in play here. I assumed your levels were fine and the SWG was on its last leg. Doesn't the Compupool give a flow error if the salt level isn't adequate? Anyway...
    1. Need a full set of test results (from a good kit...did you get your TF-100 yet?)
    2. Say hello Pool School and goodbye pool store
    3. You are going to need to tackle this manually until you levels are right. Then you can worry about the SWG.
    Your SWG may be on the fritz but it may not be a concern at this moment.
