Thread: Help, Compupool CPSC 36 control board not working
    CPSC 36 unit purchased a little less than three years ago. There was no power to the board and the fuse needed to be reset. After I did that, there is power to the board but once it powers up to 10% output, it shuts off momentarily then restarts the same cycle again. Anybody experience a problem like this? Am I out of luck?
    16K Vinyl in ground pool.
    16K IG vinyl liner - 2.5 HP Hayward Pump - Hayward Sand Filter - CircuPool Si 30 SWG
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Help, Compupool CPSC 36 control board not working
    sorry, don't know...did you try asking Compupool?
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Give Compupool a call Jason in customer service is helpful/friendly.
    Aug 2010
    Dallas, TX
    4,052
    With any luck you'll get a discount on the new unit.
    Call them. They have been very helpful to me.
    I was having a problem similar to that and it turned out that my connectors were corroded where they plugged into the cell.
    I ordered a new set of connectors and it worked perfectly.
    You could try to clean them but mine were really bad.
    Or ... maybe you have a different problem.
    Hal
    "Whatever happened to the guy who drained his whole pool?"
    27,000 gal plaster in-ground
    Compupool 40k SWG from eBay - works great!
    Polaris 380
    Hayward DE
    1.4 HP Hayward Northstar pump
    Two FAFCO Solar Bear panels now heating the pool!
