Thread: Power Off Pool to Backwash??
    May 2014
    South Carolina
    9
    Hey Everyone,
    Ok, I've suddenly become responsible (long awful story) for a green swamp. I was told by my dad that I need to shut off the power to the pool to backwash. Is this really correct? It seems strange to me somehow because I'm wondering how it will pump with no electricity?? Is my thinking off here? Could anyone please give me a heads up?
    Just some details about pool. Sorry I don't have much. I've just started learning all this today.
    In-ground
    Gunite
    Has a deep-end
    Uses sand filter
    My dad started bringing it back up about a week ago. It was uncovered and not tended all winter (like usual), so it's not black anymore but it's still emerald green. He's not a resource. I have to do this all on my own. I did manage to ask him about 3 questions (when to backwash, how to backwash, if we had chlorine) but that's it he's angry from the questions now, so I can't ask him anymore... so I'd really appreciate anything anyone can throw my way.
    Thanks
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,023
    Re: Power Off Pool to Backwash??
    What he means is, Don't move the backwash valve while the pump is running. You'll blow the seals.
    Shut the pump off, move the valve to backwash, turn the pump back on. Shut the pump off, move the valve back to normal, turn the pump back on. With your sand filter, there may be a rinse cycle in there; it sort of depends on what type of backwash valve you have; multiport or slide. Just remember to shut the pump off any time you're moving any valves.
    You want the pump off any time you are switching the position of the main valve. Then turn the pump back on to backwash. Then off to switch the valve back to filter. Etc.
    May 2014
    South Carolina
    9
    Oohhhhh ok thanks both of you, what a lifesaver! Thank you both so much.
