Results 1 to 12 of 12
Thread: Still with the sand coming through return lines--concerned and confused
    May 2014
    Birmingham Alabama
    13
    Hi. I have an 18 ft ag pool w/a waterways 19 inch sand filter and hayward pump. I posted a while back about problems with sand in the return line, thinking maybe I'd put in too much filter sand when I replaced it earlier this year. My kids are starting to look at me funny b/c I'm spending so much time at the filter trying to pinpoint where the problem is--I can hear a definite gurgling but there's no water coming from any connection on the filter or the pump. I replaced the 7 function multiport valve over the winter and it seemed like a really simple gig, but I *swear* that's where the gurgling is coming from! I can understand how a faulty seal in this piece would let sand into the return lines (sort of) but I'm clueless as to what I need to do to fix it and our budget really, really can't take on me screwing something else up so I'm really hesitant to start unscrewing stuff and messing around. How do I even begin to take the filter apart now that the pool is open and the water level is where it should be? Do I need to drain below the return line again? It also appears that the pressure gauge doesn't work--not sure if that fits into the situation or not. If anybody can walk me through what I need to do to troubleshoot or fix the problem, I'd be really grateful. With the boys out for summer, this pool goes a long way toward keeping Mommy sane. Thanks so much. --Leslie
    30,421
    Re: Still with the sand coming through return lines--concerned and confused
    "Gurgling" implies to me that air is getting into the system. Is the pump strainer basket full (completely) of water or is it sloshing around?
    Replace your pressure gauge. It may or may not be related to your "gurgling" issue but a pool needs a good gauge so you can manage your water properly.
    May 2014
    Birmingham Alabama
    13
    Thanks. I plan to replace the gauge, just waiting for pay day. The pump strainer basket appears full, I can see marginal bits of debris circling around (the new pump has a white strainer basket, so I can see this more clearly than the last pump) but I'm not seeing bubbles or anything like that.
    30,421
    Well, since the pump basket is full of water with no air coming in, I am stumped to figure out what is causing the gurgling sound.
    Maybe someone else has an idea.
    That gauge will cost less than $10.00
    May 2014
    South Carolina
    17
    Sand getting back into pool sounds like some internals maybe broken inside the sand filter. The sand has to be removed in order for the internals to be checked.
    Apr 2013
    North OKC Area
    300
    Was the replacement valve an exact replacement? Does the o-ring on the valve where the stand pipe goes in look ok? Does the spider gasket look ok? If you don't find a problem you need to remove the sand, being careful not to damage the laterals. Once the sand is removed you need to inspect the stand pipe and laterals for damage.
    May 2014
    Birmingham Alabama
    13
    Quote Originally Posted by DanielP View Post
    Yes, the replacement was an exact replacement. I had to go to the Waterways site to find it. I checked over the laterals and cleaned them really carefully when I replaced the sand about a month ago and they were fine. What am looking for re: the standpipe? It was not damaged (that I could see) when I had the filter apart. Can someone help me find a blown apart diagram of the filter? The instructions and manual don't include this (in fact, they show a similar but not exact sand filter in the assembly directions) and I'm pretty useless w/o something visual. Thanks.
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    Did you add water to the filter basin (to cover the laterals...or whatever those tubes are called) before adding the sand? My new filter has a warning about doing this to avoid damage to the laterals by the falling sand.
    Do you have a model number on that filter? Post it, and I'll help you search. You might email Waterways to see if they have a diagram.
    does this look correct?
    http://www.spapartsshop.com/Waterway...andFilter.aspx
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
    Apr 2013
    North OKC Area
    300
    The standpipe is the vertical pipe between the valve and laterals. There should be an o-ring in the hole on the valve where that pipe fits into the valve to keep sand and junk out of the laterals. If it is in place and your spider gasket is good, then the only other possibility is something below that connection which typically means a broken lateral at the bottom of all the sand which are very delicate. To check laterals, you'll have to remove all the sand. I prefer using a wet/dry shop vac and empty the vac into 5 gallon buckets when it gets full. You can reuse the sand.
    17,100 Gal 27' x 52" AGP steel wall vinyl; 44gpm Cooper sand filter; Hayward 1hp sp1580 single-speed; 1.5" plumbing, 1 skimmer/jet, inline chlorinator.
    Chlorine / CYA Chart | SLAM Process | Chlorine cost/fl. oz calculator
    Jul 2011
    N. Ga Mountains
    151
    I just did all of this and the shop vac worked beautifully. We found a very small chip at the top of the return pipe and used water weld to fix it. No more sand in pool ! It was a big job but worth it!
    33 ft round x 52", vinyl
    Hayward 1.5 hp pump
    sta-rite 2.18ft ,200 lb sand filter
    24500 gal.
    Hayward Salt & Swim3
    Apr 2013
    North OKC Area
    300
    Thanks for letting us know, glad you have it working again!
    May 2014
    Birmingham Alabama
    13
    Yes, I did add the water to protect the laterals--I know this because the friend who was helping me was delayed so I had time to double check the instructions for inspecting the laterals and adding the sand etc. Since I'd had to replace the pump this year, *everything* else got done with extra care b/c I didn't want to risk busting something else. I guess that's why I'm frustrated--I had the manuals and the laptop out there while I was going checking the filter assembly to make sure I didn't miss anything. I will look for the model number on the filter--the link is really similar, but (from memory) I think I noted some differences. Thanks.
