Thread: Draining Intex pool to re-level ground
    Mandolina's Avatar
    Apr 2014
    Los Angeles USA
    67
    My husband and I had our gardener level our non-sodded space. Then my husband and I dug out paver holes, leveled them and placed the pavers -- lot's of hard work and we're going through a heat wave. Did I mention we are elderly? Anyway, some of the pavers were a 1/8 inch to 1/2 inch off and we decided to go ahead and set up the pool. Pool is about half full and we see there is 1 3/4" difference between the high side and low side. We are now draining the pool. When the pool is empty we will break it down, fold it up and remove it. We will remove the two Gorilla Pads, the tarp and the 16 concrete pavers. Then we will have a slightly more compressed site with a circle of 16 one inch paver holes. Any ideas on the easiest way to get the ground level from this point? Thanks!
    16' x 48" 5000 gal. Intex Ultra Frame AG Pool, Los Angeles, CA
    Hayward Full-Flow Cartridge Filter System with 2 Speed Power-Flo Matrix Pump,
    Intex SWG, Intex Wall Mount Surface Skimmer, Solar cover & Solar Roller,
    Confer Plastics A-Frame 7200 Adjustable Roll-Guard Safety Ladder,
    Kokido SkoobaMax Vac, Custom Canine entry & exit ramps,
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: Draining Intex pool to re-level ground
    A 4' level and 10' 2x4, start at the lowest point and dig towards the high side. With it being only 1-3/4" off, you won't have to take much to get it level.
    Casey's Avatar
    SW PA
    10,457
    Definitely dig down the high side. Do not fill in as the weight of the pool will compress the fill and knock it out of level again. It's hard work.
    + 1 on both replies above ↑↑↑↑↑
    Also....you're making the right decision and re doing it now.
    Intex Ultra Frame 18' x 52"
    Intex 3000 gph Sand Filter Pump, Intex Salt Water System SWG
    Hayward Thru Wall Skimmer and stock return line
    Two Hayward I lets
    Florida/Alabama
    Mandolina's Avatar
    Apr 2014
    Los Angeles USA
    67
    Yes, it was hard work. We did it right - still had a little level adjustment to two of the legs after the pool was set up, but before we added the water. Now to figure out the pump and filter and SWG.
    About two inches off after re-measuring and re-checking. My husband said that was more shoveling than he had done in his whole life. He was very resistant to taking the earth down to the lowest point, but eventually that is what he decided to do. I even helped with a few shovels full. Getting the pavers level was also an experience.
