Thread: Start up after replaster, sequestrant needed even if water tests negative?
    Aug 2011
    Southern California
    188
    I'm looking at a start up on Wednesday after the mini pebble replaster has been acid washed. I've had my water source (city water) tested for metals and it has come back at zero. My question is it still advisable to use a sequestrant in the start up procedures here- https://npc.memberclicks.net/assets/...nt-rev3.09.pdf
    These are recommendations that I was given to follow by the manufacturer, Stonescapes. On the First Day, Step 6 it says, "Although optional, it is highly recommended to pre-dilute and add a quality sequestering agent...". If I have no metals and it's optional, I would just prefer to not have the additional chemicals in the water. However, if it's found to be a benefit, even without metals detected, then I have no problem adding. Just not sure which way to go on this.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Start up after replaster, sequestrant needed even if water tests negative?
    If it was my pool, I'd add the sequesterant. When we replastered, our pool was filled with municipal water that also tested metal free. However, upon addition of chlorine, pool turned green. I consider the addition of sequestrant insurance.
    We also recommend it in our Plaster Start-up Procedure in Pool School here:
    http://www.troublefreepool.com/conte...w-pool-plaster
    You're done SLAMing when:
    Butterfly's Avatar
    South Carolina
    10,045
    Also, the National Plasterers Council also recommends adding sequestrant.
    http://www.npconline.org/start-up-card
    Sequestrant is good insurance. The odds of metal in the water is low, but if there are metals in the water they can form stains, and staining during the first few days becomes embedded in the plaster and can not be removed. That can be very expensive to fix, so worth a few dollars to avoid even if it is unlikely.
    Aug 2011
    Southern California
    188
    Quote Originally Posted by Butterfly View Post
    As I quoted above, it says optional. Although I see your point.
    But considering the investment made, another 50 bucks is nothing...
    Any recommendations on brand? Was thinking The Pink/Blue Stuff by Jacks Magic
    Jack's The Blue Stuff is excellent for fresh plaster. If you can't find that there are several other good brands, including ProTeam and HTH.
