Thread: board went bad I think... need help
    carl292's Avatar
    Jun 2012
    TAMPA, FLORIDA
    45
    Hi everyone, I have a aquarite swim pure and I was told by pinch a pny that the board went bad. Just replaced it a lil over a yr ago. Basically when it turns on the no flow appears after about 30 seconds it goes away, the generating light comes on for 5 seconds and shuts off. No power light or any other lights appear on the right side, but all the display functions work fine/. I am being told it is $319 for the board. It seems very expensive for something that was replaced not too long ago. Advice/ thoughts???
    Re: board went bad I think... need help
    That sounds kind of like the common current limiter problem. See here for more info.
    carl292's Avatar
    Jun 2012
    TAMPA, FLORIDA
    45
    Thank you! Now the next question is it the SL32 or the AS32 current limit switch? The repair guide shows 2 different part numbers and so does the website to purchase. I think they have different ohm ratings.
    carl292's Avatar
    Jun 2012
    TAMPA, FLORIDA
    45
    Ok, parts came in from digikey.com and i am use my old solder iron and for some reason the item i am trying to desolder will not liquify to be pulled out. I can melt solderfrom a new roll, but the stuff in the board will not loosen so i can pull the piece out. Just gets a lil brown and nothing. New solder iron or ???. What u guys thinks ? Thanks
    AQUARITE SWG SYSTEM, HAYWARD T15 CELL, CARTRIDGE FILTER, 23K RECTANGLE POOL , MARCITE FINISH, TF 100 Test kit
    "LIVE EACH DAY AS IF IT WERE YOUR LAST"
    Sounds like the soldering iron is not hot enough. Have you replaced the tip? Even a cheap soldering iron and desoldering braid should do the job you're trying to accomplish.
    Apr 2014
    Anderson, SC
    20
    Try adding a little new solder while the hot iron is sitting on the bead you are trying to remove. It will help transfer more heat from the iron to the board.
