Thread: Panel and easytouch problems
    May 2014
    United States
    5
    Post Panel and easytouch problems
    I had a few power outages on my area. Since then this are the problems i'm having with my equipment
    my light on the pool and spa only turn white
    If i press my pool light button my water features turns on then the valve stays open,it won't close
    if i turn the jets on my spa the heater still comes on even though i have it off not to come on
    the water temperature of pooler spa doesn't read accurate.
    I will appreciate any kind of help
    Thank You
    Melvin
    16,000 gallon gunite with 800 gallon spa. 450 mm pentair filter. circulation pump sta-rite VS-450
    400,000 B.T.U. pentair max-e-therm heater @ spa. 2 water pots.
    Re: Panel and easytouch problems
    Welcome to TFP!
    It sounds like your automation panel might have lost some of it's programming. What kind of automation panel do you have?
    May 2014
    United States
    5
    easy touch pool and spa panel by petair
