View Poll Results: do you use a step/stair pad?
Voters
21. You may not vote on this poll
  • yes
    13 61.90%
  • no
    8 38.10%
  • other
    0 0%
Results 1 to 13 of 13
Thread: Ladder/Stair Pads - do you use one?
    Aug 2013
    south east Arizona
    199
    Curious how many actually use these things. I bought one for the new steps, but after I lifted the small one I had under the "included" ladder (that didn't actually even fit the ladder) it was kind of gross and slimy under there. I am a little concerned about using the larger one I bought for the new steps.
    hmm, there is an option for doing polls but I don't see how it is implemented...oh well tell me about your step pad or lack thereof, please.
    edit - I see the poll gets added after you submit the post. sorry for any confusion (beyond my own LOL)
    somewhere around 6,800 gal 18 x 4 foot round Intex Ultra Frame AG, finished filling August 29, 2013. toy pump w/ "A" cartridge up and running next day --- July 2015 upgraded to Krystal Clear 3000 GPH pump and 16" sand filter --- May 2016 Intex auto cleaner and in July salt system and Hayward skimmer
    Casey's Avatar
    SW PA
    10,453
    Re: Ladder/Stair Pads - do you use one?
    Hello Pv2! Hope you're having a great evening!
    I don't use a pad under my steps. My steps have 4 little feet on them that keep the whole steps up off my liner except for where the feet are and they are slatted so water goes through. I haven't had an issue with them breeding algae. Sure they get a little dirty but I move them and brush under them and move back to where they were.
    Once I get my deck on, I will have those weighted bleach bottles on the inside of the steps. It was cold when I put those in so I just hooked them on with the bungee cords.
    For our 14x42 the ladder has hard rubber feet. With sharp edges. I cut the edges...but still was worried since two girls in/out.....in/out.
    So I bought two bath tub anti slip mats with the suctions cups and both legs sit on each.
    Intex Ultra Frame 18' x 52"
    Intex 3000 gph Sand Filter Pump, Intex Salt Water System SWG
    Hayward Thru Wall Skimmer and stock return line
    Two Hayward I lets
    Florida/Alabama
    dattia's Avatar
    Jun 2008
    West Chester, PA
    511
    I have stairs and have never used a pad. I also do not have mine anchored in any way and move them around frequently.
    27' round AG
    Hayward Matrix 1 1/2 HP Pump
    Hayward S210T Sand Filter
    JenMichelle's Avatar
    Apr 2014
    St. Louis
    65
    I was wondering this myself, I have a vinyl liner and I was worried the stairs may cause a rip in the liner over time (I have two boys coming in and out of the pool). I have them anchored to the deck, but the bottom still moves a tiny bit as people climb in and out and I am afraid it will cause wear and tear?
    24' x 52" AG / Hayward Sand Filter
    Hayward Power-Flo 2 Speed Pump
    TF100 test kit / Pool Rover Hybrid Robot
    St. Louis, MO *GO CARDINALS*
    Pysiek's Avatar
    Apr 2012
    Frankfort , Illinois
    419
    Quote Originally Posted by Casey View Post
    Why have you used bottles instead of filling the steps with sand as recommended per manufacturer? Is it better the way you did it?
    Quote Originally Posted by JenMichelle View Post
    I did bought one with my stairs. Like you said I'm afraid the stairs will tear the linear from moving left and right
    30'x54" Quest Above Ground Round Pool , About 21,000 Gallons , Hayward Perflex EC50 D.E. Filter System 1.5HP Power-Flo Pump , TF-100 Test Kit , Two Hayward Main Drains on the Bottom , Hayward CL200 In-Line Above-Ground Chlorinator.
    77"x77"x21.5" Hot Tub
    Aug 2013
    south east Arizona
    199
    Thanks all! I guess since I bought the stupid thing I will try it out (when I move the steps, right now they are still tied to my...uh..."entry system" LOL. - This consists of a ground set of masonry scaffolding positioned with a short side just against the pool, one side open and the "X" brace side topped with a 2x4 so nobody trips up over the brace. Then the ladder part of an old set of pool steps braced against that and all of it tied with baling twine to the inside ladder.
    Casey - like you, I have a jug full of sand/gravel and water to hold the stairs down. I intend to hang a few of them on the inside as well. I am curious if your stairs really stay in place well with multiple jugs and no "anchor" ties or other attachments to the pool wall or decking? that would be great, and much easier to deal with cleaning. I saw no reason to try and put sand inside my pool step frame. that sounded like a huge disaster. removable weights are the way to go!
    I did make the mistake of leaving the stairs in over the winter and that was a mess. Birds made a lot of "deposits" at that location, trying to get water out of the area.
    kyles974 - the suction cup pad sounds like a good way to keep it from slipping around.
    JenMichelle - I can tell you that 20 years ago I had a cheap ABG pool from Sears that came with a painted metal ladder. It had a bolted on base that was made of wood. The bolts eventually rusted/corroded enough that I did get a hole in the bottom of the pool - easily patched and never another after switching to a plastic set at the 7 or 10 year point. I don't think they had stair pads back in those days. Heck the internet was barely there. Anyway I wouldn't worry too much either way. Get a pad if you have the spare money - don't worry if you don't.
    Pysiek - using removable weights makes it easier to get the steps out of the pool for whatever reason. 3 or 4 10 to 20 lb jugs or other containers vs a 100 lb or more large ladder. If you take it out for storage every winter and then move it someplace like a basement or garage that makes a big chore.
    Pysiek's Avatar
    Apr 2012
    419
    Quote Originally Posted by Pv2 View Post
    It looks like instead of throwing those bleach bottles away I will need to save some
    Casey's Avatar
    SW PA
    10,453
    I have sand in the steps and I hate them filled with sand!!! I regret it because they are sooooo heavy that when we took them out last year, the steps busted apart as they hit the ground. I would rather weight then down than follow manufacturers directions and STILL have them float! They seem pretty stable with the bottles and once I get my deck on, I will put them on the inside of the steps.
    Pysiek's Avatar
    Apr 2012
    419
    Thanks Casey. I'm glad I did find out about the bottles. I'm going to install my steps before this weekend. Started slamming the pool last night and already have 3 bottles
    Aug 2013
    south east Arizona
    199
    kick to see if we can get some more data
    Orlando, FL
    690
    I have two sets of steps and pads under both. I moved the oldest pad recently and there was nothing under it. I use them so that I feel better... I'm a worrier. One set of steps is filled with water. The other set, I just put an old 10 lb weigh behind it and a big brick is on the bottom step. I intended to move the brick to the intended location behind the steps but the five year old uses it so I left it. I covered it so that it doesn't accidentally damage the liner.
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    Casey's Avatar
    SW PA
    10,453
    Last year, my girlfriend n I took a drill n drilled holes into the steps n flushed all that sand out of them. It was ridiculous n so glad we did it. I'm using 8 bleach bottles of sand and bungee cords to hold the bottles in place under my steps. Then, I attach my steps to my top rail using bungee cords. I will take a pic of my set up tomorrow before I lay out. It's a great way for me to keep the steps secured yet I can move them by unhooking the cords.
