Results 1 to 16 of 16
Thread: just had pool opened.....now what?
    Jul 2012
    Herndon, VA
    419
    Pool service came by today and opened pool. Didn't look too bad.
    He said he put in 3.5 to 4 pounds of dichlor, and 1 quart of algaecide.
    I just tested, and FC is 36.
    Does algaecide add to FC?
    8,000 gallon, in ground, fiberglass pool with a cartridge filter.
    Re: just had pool opened.....now what?
    No, algaecide does not add to the FC level. 4 lbs of dichlor in 12,000 gallons would raise FC by 22 (and CYA by 20).
    Jul 2012
    Herndon, VA
    419
    Just tested again:
    FC 36
    TA 50
    CH 130
    Based on the FC level, and the assumption that there would be no FC at all when we opened, it looks like he put in more like 6.25 pounds of dichlor.
    Is this a valid assumption?
    Based on the TA level, I need to add about 3.5 pounds of baking soda to bring TA from 50 to 70?
    There's no point in testing the PH right now, because the FC is so high?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    I wonder if the algaecide was really algaecide and not some sort of "yellow-out" or "green-to-clean" or miracle-snake-oil algae killer? I suppose you'll find out for sure when you test the CYA level. Hopefully, it's not astronomical. Be a shame to pay someone to open it up and then have to pay to replace a bunch of water.
    And you are correct, no point in testing pH. You did use the right factor for the drops, I hope? .5 for a 10 ml sample, .2 for 25 ml. It's easy to make that mistake, since the TA test is 25 ml.
    Jul 2012
    Herndon, VA
    419
    I used a 5 ml sample, so each drop is 1 FC
    Casey's Avatar
    SW PA
    10,450
    Personally, I'd fire the pool boy and take over pool maintenance myself. It's not hard at all. By reading Pool School and owning your own test kit, all you need is to make time for the pool which, 5 minutes a day could cover. Good Luck with it. Keep asking questions!
    Jul 2012
    Herndon, VA
    419
    I do the pool maintenance. I only use the pool service for opening and closing. I may attempt closing by myself this year, with the help of a neighbor.
    So, with a TA of 50, I need to raise that up to at least 70?
    30,426
    To perform what test?
    Jul 2012
    Herndon, VA
    419
    I used 5 ml sample to perform the FC test.
    30,426
    There is an article in Pool School (Recommended Levels) that will tell you where to maintain your TA (and other parameters).
    Jul 2012
    Herndon, VA
    419
    so I need to add about 3.5 pounds of baking soda....
    do I just sprinkle all around the pool?
    another question...
    I don't receive email notification of replies to my posts, even though I checked that off in the settings. How do I fix this?
    Richard320's Avatar
    Jan 2010
    19,037
    Quote Originally Posted by GuinnessPhish View Post
    another question...
    Straight from the article on Recommended Pool Chemicals: "Baking soda can be added by spreading it across the surface of the deep end of the pool."
    Can't help with the forum issue. I checked mine so I don't get emails every time.
    38,371
    The issue here may be the assumption that FC was 0. Your CYA may now be too high as well. This is why we always say you need to test before making adjustments.
    Jul 2012
    Herndon, VA
    419
    The reason I assume FC was zero was because the pool did have some algae when opened.
    The pool was drained about a third at closing, but I did have to siphon water off a couple of times because of all the snow and rain we got this winter.
    Check to see if the notification of new posts message is going into your SPAM folder.
    Jul 2012
    Herndon, VA
    419
    Quote Originally Posted by JasonLion View Post
    nope. nothing there either.
    weird.
    Anyway...pool water is crystal clear! I raised TA up to 70. pH 7.2, CC .5, FC 7.5...
    CYA is assumed to be around 32...I'll test on Saturday to confirm.
    The only real question I have at the moment.....my CH is 130.
    Should I raise that, or can I just bring my pH up to 7.5, so the CSI is above -.6?
