Page 1 of 2 12 LastLast
Results 1 to 20 of 32
Thread: Surface Scum
    Oct 2013
    Bluffton, SC
    8
    Surface Scum
    I am a 4 year owner of a gunite pool located in Bluffton, SC and have the water chemistry thing down fairly well. I have an issue that is new this year that I haven't seen in previous years. The water surface is covered with clear matter that I can't identify. Attached are 2 pics showing what it looks like. The water is perfectly clear and fairly well balanced (FC=5 ppm, CC=0, TA=100, pH=8.0, CH= 250, CYA=55). I have tried running the 2 speed pump on high and suction set to skimmer for 8 hours, but the next morning the stuff is still on the surface. When I try to skim it off with a net it just seems to disperse into smaller pieces. I backflushed the filter and the gauge reading is 10.5psi which is normal. The filter media has never been replaced or chemically cleaned, but based on consistent pressure readings of 10.5psi after flushing, doesn't seem to need it. It is a gunite pool, plaster, 11000 gal, Hayward 1 HP 2-speed pump, Triton TR-60 sand filter, Hayward CL-220 chlorine feeder. Does anybody know what this stuff might be and how to get rid of it?
    30,431
    Re: Surface Scum
    Welcome to the forum.
    I am not sure what it is but a remedy that is normally very successful is to simply elevate your chlorine for a day or two and run the pump 24/7 until it clears.
    I would bring the FC up to around 8-10 ppm with your CYA of 55 and I bet that will clear it out if you keep your pump going.
    I know you didn't ask but your pH is a little high at 8.0.....I would suggest 7.5 or so.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,652
    Re: Surface Scum
    Most likely pollen.
    Casey's Avatar
    SW PA
    10,457
    Re: Surface Scum
    Quote Originally Posted by woodyp View Post
    Most likely pollen.
    That was my first thought...
    Beens's Avatar
    Jul 2013
    Virginia Beach, Va
    1,171
    Re: Surface Scum
    I saw some of that on my surface a week or so ago. I figured it was some sort of pollen issue. I'm pretty sure it went away (filtered out) a couple days later. Haven't noticed it again.
    18' x 48" (42" water depth) Intex Metal Frame 6,700 Gallons
    Hayward Power-Flo LX 1.0 HP pump
    Hayward Pro Series S166T Sand Filter
    Original Intex Floating Skimmer
    Oct 2013
    Chapin, SC
    1,141
    Re: Surface Scum
    Mine here near Columbia has the same thing (overnight), but mine appear to be a little smaller, almost snowflake like. Like you said they break apart, and when the pump runs, after a while they are gone! At first I thought they might be salt flakes since this is the first time I've seen them, and I have salt for the first time too! It doesn't seem to have affected my filter pressure. I back wash about every week or more since getting rid of the excess water due to all the rain we've had recently.
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    605
    Re: Surface Scum
    We had something very similar a few weeks ago. It was coming from 3 Bradford Pear trees that were blooming and greening up. The wind was blowing it in the pool as the trees are about 30 feet away.
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
    Beens's Avatar
    Jul 2013
    Virginia Beach, Va
    1,171
    Re: Surface Scum
    BRADFORD PEAR!! My arch nemesis! I hate that stupid tree!
    Oct 2013
    Bluffton, SC
    8
    Re: Surface Scum
    Thanks for the suggestion Dave. Am elevating FC and running pump now. We'll see how it looks tomorrow!
    Oct 2013
    Bluffton, SC
    8
    Re: Surface Scum
    In my case it can't be from trees or windblown source because the whole pool is screen enclosed. I'm elevating FC now and running the pump 24/7 for a day or so to see if it clears. Keeping fingers crossed!
    Oct 2013
    Chapin, SC
    1,141
    Re: Surface Scum
    Beens I take it the bottom pic was taken last year or longr?? No Bradford Pears that I can see around here! My flakes disappear a short while after my pump starts and don't come back till the next morning.
    Beens's Avatar
    Jul 2013
    Virginia Beach, Va
    1,171
    Re: Surface Scum
    I hope it clears for you wshale, I noticed the reflection of the screen enclosure. I wish I could put something around my pool but the only thing I've ever found is close to $1000 and for my pool that would be silly! When I move to Florida I am buying a house with an inground pool with the screen enclosure! (Hopefully not living in a dream world..) I'm still thinking it's some kind of pollen that sorta forms together like flakes on the water. Mine was also smaller and looked kinda like snowflakes. (great description timerguy) Maybe it's tiny stuff that can float around through screen etc and then gathers together on the surface. Blech.
    Timerguy, the second pic was actually from about a month ago. The leaves had just come out and we had a bad storm. I guess they weren't strong enough yet and they ripped and pulled from the tree very easily from the wind. I had taken the net off because the flowers and garbage weren't falling as bad. I saw the forecast before work that day and ran out of time to throw the cover back on. I took a pic of the aftermath the next morning. :-\
    Thank God for my leaf net. It will have to go back on around july/august when that idiotic tree starts dropping it's little evil marble-like "pear" things in the pool.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Surface Scum
    Quote Originally Posted by wshale View Post
    With CYA 60ish, you should maintain the FC between 5 and 7, and never below 5. Since the CYA test is +/- 15 or so, I suggest you round up CYA on the FC/CYA chart for slightly better FC coverage. If you have maintained the FC at the low end for the CYA value, conditions could be ripe for a situation. My first thought, looking at the pics, was white tissue mold. I'm not saying that is what it is, but it is a possibility.
    The good news is, as Dave mentioned, raising FC level will kill it (and all organics) , but it may end up that a full on SLAM is needed.
    White tissue mold/white water mold is uncommon in chlorine pools unless the chlorine level is kept too low and even then it's pretty rare. Nevertheless, what you describe sounds like white water mold -- tissue-like on the surface of the water that breaks up when you try and remove it from the water. If you determine that it is white tissue mold, SLAM'ing will get rid of it, but you should check for other places it might be hiding out such as light niches or under ladders.
    You're done SLAMing when:
    Oct 2013
    Bluffton, SC
    8
    Re: Surface Scum
    Thanks Butterfly! If it isn't gone tomorrow, I'm going to full SLAM mode. Will be making a run on the local Walmart for bleach today!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,055
    Re: Surface Scum
    The only time my pool has lookd like that was after a long barbeque session on a very windy day. Super-fine ash and probably greasey smoke settled on the pool. Went away with filtering.
    Oct 2013
    Chapin, SC
    1,141
    Re: Surface Scum
    No flakes this morning! Just a dead frog in the skimmer.
    JesseWV's Avatar
    Apr 2011
    North Central WV
    526
    Re: Surface Scum
    I also think it's pollen which has the same "clumping" action in my pool. Unfortunately your screen can't filter fine particles. Most screens are 16 mesh, but even smaller 20 mesh screens have openings that are 841 Ám. Pollen is 100 Ám or smaller and goes right through.
    16k gal, 28'x3.5', Vinyl A/G, 1hp Pentair Dynamo 2-speed Pump, Hayward S160T Sand Filter, Intermatic HB800RCL Digital Timer, Intex 8110 SWG, TF-100 Test Kit, SpeedStir Author: Jesse's Graphical Pool Testing Log
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Surface Scum
    Have you tried using skimmer socks ?
    Jeff
    Oct 2013
    Bluffton, SC
    8
    Re: Surface Scum
    No, Jeff I haven't. Do they just sit in the skimmer basket? Where can I buy them online? Thanks!
    Scott
  20. Back To Top    #20
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Surface Scum
    Yes they just float in the skimmer. I would imagine any pool supply website. Try a search on my best friend google ! 😎
    Jeff
