Thread: Caulk
    Jun 2013
    Southeast Pennsylvania
    125
    Caulk
    Anybody have a recommendation on caulk?? My pool deck is up against my poured concrete foundation. Here is the layout. Looking overhead, there is the foundation, 1/2 inch expansion foam, decko drain, stamped concrete deck. The foam allows for the expansion and contraction of the deck. As designed, you peel off the top layer of the foam strip....about 3/4". So, between the poured concrete foundation and decko drain, I need to caulk. I supposed I need the kind that goes between poured concrete decks and brick coping??? Can I get this at Home Depot or lowes?? Any advise? Thanks, Doug
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Caulk
    I've never caulked but I know this question has been asked before...just can't remember the answer!
    Re: Caulk
    I would recommend a self-leveling caulk, such as Sonneborn NP1 or SL1. You can get it at just about any lumberyard.
    I actually came in here to ask a different question about caulk. Inside my skimmer is a caulk joint that has failed. Is this just a latex caulk, or something special?
    30,413
    Re: Caulk
    Polyurethane caulk will do best for both of you.
    I don't like self-leveling as it will tend to sink after you are done with it.
    Use masking tape on both sides of the joint and use a putty knife to make a professional looking surface.
    Poly is messy but much better than acrylic for those applications.
