Thread: Cement Pool Pad
    edgy28376's Avatar
    Jun 2013
    Harrison Arkansas
    10
    Cement Pool Pad
    After reading a few of the posts about using concrete I have a few questions.
    1) What psi of concrete should be used?
    2) At what thickness did you use? 4" or 5"
    3) How long do you have to wait before setting the pool up?
    4) Did you use any slope on the pad? e.g. 1/4" per 4'
    INTEX 18'x48" Ultra Frame Pool (6700 gallons)
    Hayward Diatomaceous Earth Filter
    INTEX CS8110 Krystal Clear Saltwater System
    TF-100 Test Kit
    Hayward Skimmer
    Re: Cement Pool Pad
    I'm on the same boat, got an estimate today. He said standard 4" should be fine, due to even spread of the load. I'm going to wait a week before the pool install, I'm putting up a 18' as well. I think it's 1/4" first 4' from the house and then 1/8" then after.
    Re: Cement Pool Pad
    1) Not crucial. With a well spread load anything will work.
    2) That depends on soil conditions. If you get a lot of shifting/heave in the winter, or you have loose soil that might shift, you want a thicker pour.
    3) Four weeks is ideal.
    4) The pool needs to be level. Even a 1/4" per 4' would put a 16' pool right at the limit for slope and that is assuming everything else was perfect.
