Results 1 to 11 of 11
Thread: Sand Filter issue
    May 2013
    Washington, Il
    40
    Sand Filter issue
    When I move from filter to the backwash I lose pressure in the filter trap. Why would this be happening?
    40,000 gallons (20' x 40'); IG; vinyl liner
    sand filter
    BBB method for 2 full seasons
    tf100 test kit
    central Illinois
    Re: Sand Filter issue
    "filter trap"? I'm not sure what you are referring to.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,591
    Do you mean in the pump strainer basket in front of the pump?
    Adamsaudio's Avatar
    Jun 2013
    Atl
    36
    On my sand filter, when I set it on backwash or waste, it creates a suction through the pump and skimmer even if the pump isn't on. I believe this is normal operation. If the valve isn't diverting properly, you may have an issue with the spider gasket. More details on the problem would Def help diagnose it better.
    24 ft Round Above Ground - 13500 gallons... Former Pool Frog user. Sand filter . Located just South of Atlanta
    May 2013
    Washington, Il
    40
    Yes in the strainer basket. Does it matter that I'm not using the chlorinator and water is still moving through it? Or is this likely a sign of faulty equipment like something needs replaced?
    The chlorinator shouldn't make any difference.
    I also suspect it might be the spider gasket, as Adamsudio suggested.
    May 2013
    Washington, Il
    40
    I've also noticed a drop in pressure consistently showing 10 psi less than normal. Where is the spider gasket located?
    sand filter
    tf100 test kit
    central Illinois
    Adamsaudio's Avatar
    Jun 2013
    Atl
    36
    Can you post a pic of your multi port valve?
    May 2013
    Washington, Il
    40
    Not sure what that is?
    sand filter
    tf100 test kit
    central Illinois
    Adamsaudio's Avatar
    Jun 2013
    Atl
    36
    The valve you move to take the filter to backwash. The spider gasket is under the cover of the valve that diverts the water.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    Quote Originally Posted by birkesl View Post
    It'll look similar to this:
