Thread: Intelliflo vf / Easytouch schedule
    I have an intelliflo vf controlled by an easytouch system. The pump is scheduled to run from 8:00 to 5:00 each day at 27 gpm. For some reason the pump shuts off before the scheduled time. I know the filter circuit is still active because the swg still has power and sends me a low flow error. Anyone run into this problem?
    Re: Intelliflo vf / Easytouch schedule
    Welcome to TFP!
    Have you checked the display on the pump when it isn't running and should be to see if an error message is displayed there?
    Another possibility is that you are getting the no-flow error first, as that would cause the pump to shutdown. For that, check and clean the skimmer(s), pump strainer basket, and filter to make sure you are getting good water flow.
