Thread: Plaster being eaten away by return
    Jun 2013
    Southeast Pennsylvania
    125
    Hello,
    I am a new gunite pool start up. The pool was plastered 5/5 (Quartz Finish). I have a bench and one of the returns is only about an 1 1/2 off the top of the bench where you would sit. I always thought that was wrong. Anyway, last night I noticed some discoloration on the bench right by the return. It turns out the force of the water is eating away the plaster. It is much rougher and pitted than the other areas which are quite smooth. I immediately pointed the return higher so it is rippling the surface water. The return was not directly hitting the bench, but the residual force was enough to do damage. Any suggestions on how to smooth of the area which is about the size of a baseball?
    Doug
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,409
    Re: Plaster being eaten away by return
    Have your plaster guy come take a look at it and see if it can be corrected chemically or if it need polishing or patching. What size pump do you have?
    Love TFP? Become a
    TFP Supporter!
    Jul 2011
    Arizona & California
    805
    Use 80 or 100 grit wet-or-dry sandpaper.
    Jun 2013
    125
    The pump is 1 1/2 horse. I sent a text to the guy who did my indoctrination and he said this won't happen when the plaster cures....but it's a little late for that advise. I'll reach out to the plaster company first, and if I get no where with them, I'll use the sandpaper as recommended....I just want to get rid of the roughness.
