Results 1 to 8 of 8
Thread: chemical question
    Apr 2014
    Upper Chichester, Pa
    60
    chemical question
    Just want to make sure I am right with this calculator since I am new. I have read all the boards and the pool school but just in case. Here are my results before adding the chemicals the calculator states
    FC 0.5
    PH 7.5
    CA 75
    TA 70 -----so I need to add all this baking soda????
    CYA 10 -
    Sharkline Reprieve 21' x 52" Round Above Ground Swimming Pool, Waterway 520-5220-6S ClearWater 19in. Sand Filter Above Ground Pool System with Hi-Flo Single Speed Pump, using BBB method and TF-100 kit
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    chemical question
    Here's what I would do.
    1 Get your FC up to 3 ppm with bleach.
    2 Get your CYA level in the 30-50 ppm range. Aim for 40. It's middle of the road. Then adjust FC after it's dissolved. Target 7 and don't let it fall below 3.
    3 Leave your TA alone.
    Use Pool Math to figure the amounts of chem's to add.
    For the CYA addition put it in a sock or nylon knee high, that's what I use. And hang it in front of the return with the pump running until it's all dissolved.
    Jeff
    Apr 2014
    60
    Re: chemical question
    great thanks again Jeff you are so full of knowledge I need you on speed dial lol anyway good morning
    one more question should I add the calcium the calculator is recommending or should I wait on that
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    With your vinyl liner pool you don't need to worry about the CH unless it gets really high. 😎
    Jeff
    Apr 2014
    60
    ok great that's what I thought I read just wanted to verify that part thanks again Jeff
    Butterfly's Avatar
    South Carolina
    10,045
    ^^^ what Jeff said
    How does your water look?
    You're done SLAMing when:
    Casey's Avatar
    SW PA
    10,424
    Agree with pwstrk! Get CYA up and raise FC and go swimming! Enjoy your pool!
    Just noticed you're from PA too! I've noticed a lot of new members from PA!
    Apr 2014
    60
    yay!! I can say after just a few days and the help of all of you and this site my pool chemicals are perfects using the BBB method. I am super excited since I am brand new at doing this Thank you so much for the support
