Thread: What is this? Ground cloth or winter cover?
    Mar 2013
    Central Iowa
    169
    Can you tell me what this black cover is? Is it a ground cloth or a winter cover? It feels like a heavy weight felt. We are hoping to have a second attempt at doing our pool build in about a week and I don't know where this may go. If it is a ground cloth - what is the consensus? Use it or just good sand for the pool bottom?
    The second photo is the other cover that came with the pool. I am thinking this one may be the winter cover.
    THANKS or your help!!
    2014 Used 33'x54" Wilbar Morada,deep end approx 28,800 gal.
    Hayward S180T1580S pump/filter combo,
    Pentair Aqualuminator light/return, Aquabot S2-50
    TF-100 kit, Initial fill with pond water
    South Central Iowa
    Casey's Avatar
    SW PA
    10,428
    Re: What is this? Ground cloth or winter cover?
    The first pic is a ground cloth. I actually like mine. It can protect the liner from fill dirt that has glass and stuff that can puncture the liner. I would use it over top of the sand base.
    The second pic is the winter cover.
    Mar 2013
    Central Iowa
    169
    THANK YOU!!!
    Another couple questions......the plastic coping (I think that is what it is called) that goes under the top rail and traps the liner on top of the steel wall - do those need to be replaced with a re-build (we bought a used pool)??? Or are they OK to re-use?
    Also, where can I find a plumbing schematic of the BEST way to do the hard plumbing.....something that includes where to put valves and shut offs?
    South Central Iowa
    *JLS*'s Avatar
    May 2014
    Central Georgia
    60
    I would definitely use the ground cover. We put ours over a sand base and besides needing it for liner protection, it helped tremendously when smoothing out the liner during the install. I would also recommend using the styrofoam coves - another great and easy way to save extend the life of your liner. Here's a pic of our liner just after installing over the ground cover.
    ​Jennifer
    19k gal, 27' x 54" AG Aqua Leader Saltwater 8000 installed April 2014; Aqua Pro 19" Sand Filter System 1.5-hp Pump; Hayward Aqua Trol Salt Chlorine Generator System; Overlap Boulder Swirl Liner; Polaris 65 Turbo Turtle Automatic Cleaner; TF-100 Testing Kit
    Mar 2013
    Central Iowa
    169
    Quote Originally Posted by *JLS* View Post
    OK, we will use the ground cover. We have a deep end in our pool - will it work OK with the deep end? I don't know if this pool had a deep end previously or not.
    We do have the previously used styrofoam coves and are planning on using them. I need to get some two sided tape to adhere it to the wall. I assume it is OK to re-use the styrofoam cove?
    Can I also re-use the coping that goes on top of the wall?? The little plastic pieces that trap the liner to the wall?
    THANKS for the help!!!
    South Central Iowa
    Casey's Avatar
    SW PA
    10,428
    You sure can reuse the coping strips! As far as using the ground cover in the deep end, you may have to cut it to fit with a utility knife and you may not have enough to go around the whole pool since you are adding a hopper.
