Results 1 to 9 of 9
Thread: TF-100 Arrived Today - Have Some Questions
    Jun 2008
    Houston, TX
    68
    My new TF-100 arrived today and I tested the water. Now, I have a few questions about the results. First, here are the results:
    FC - 2.5
    CC - 0
    TC - 2.5
    pH - 7.7
    TA - 260 (tested twice)
    CH - 370
    CYA - 35 (maybe 40...darn black dot)
    My questions are...
    a) Should I shock even though the CC is 0? According to Jason's calculator, normal FC levels should be between 3 and 7.
    b) Why would my TA shoot up so quickly and is it a problem? I've had the water tested at the pool store pretty regularly and it's always been in the low 100's. Late last week I dropped the pH to about 7.2 and aerated to lower it, but I never tested it again until today.
    Pool Specs:
    16,000 gal. IG - Plaster - Auto Chlorinator
    FNS 48 DE Filter - 2HP Centurion Pump (A.O. Smith)
    Hayward HeatPro Heat Pump - Polaris 360
    revstriker's Avatar
    Apr 2008
    Texas
    117
    Re: TF-100 Arrived Today - Have Some Questions
    According to the CYA / FC chart:
    category/pool-school/chlorine_cya_chart_shock
    you are right around the minimum FC that you should have. As for shock, with zero CC, I see no reason to shock unless there's something other than the numbers (cloudy, or discolored water for instance).
    I have no idea about your TA, but that is high.
    10K White Plaster Pool Built in 2007. Hayward Pump and DE Filter, Hayward Navigator, Liquidator (Removed due to issues), Solar Blanket, BBB user.
    Butterfly's Avatar
    South Carolina
    10,045
    Here is a post by duraleigh about some of the tips. See if you have this situation, and, if you do, Dave will correct it for you!
    to-all-tf-100-purchasers-since-june-1-2008-t7515.html?hilit=tips
    You're done SLAMing when:
    Jun 2008
    Houston, TX
    68
    Quote Originally Posted by jjparrish
    I was just reading that thread and I do think I have a bad tip. It was difficult to get the drops to come out one at a time. I would squeeze very softly and two drops would come out very quickly. I will shoot Dave an email.
    Pool Specs:
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Quote Originally Posted by h2o
    Try wiping the tip with a damp cloth before you use it. Seems to be a static issue.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    The darn black dot....
    maybe this will help. Scroll down and see the pics.....
    http://www.taylortechnologies.com/Chemi ... ntentID=44
    Jun 2008
    Houston, TX
    68
    Quote Originally Posted by frustratedpoolmom
    Thanks for the link, that helps. I would have to say my CYA was closer to 40 then.
    Pool Specs:
    Jun 2008
    Houston, TX
    68
    Okay, so I went home yesterday and re-tested the TA. I wiped the tip of the R-0009 reagent with a damp paper towel before I used it and it worked perfectly. My TA was actually only 100.
    Thanks for all of the responses!
    Pool Specs:
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by JohnT
    Thanks for the correction, JT. I should have referred to this post by duraleigh: possible-clue-for-dropper-tip-issues-t7645.html?hilit=tips
