Thread: Any problem swimming in pool without pump operating
    I'm wondering if there is any issue with swimming in pool without the filter and pump running? I am installing a solar heater and got the piping all cut etc and changed my mind on the check valve. I won't be able to get the new check valve until Monday. The pool is currently clear and chlorine levels are where they are supposed to be. If kids are swimming this weekend, is that okay? My thinking is it should be okay but I want to be sure.
    Ken
    Casey's Avatar
    SW PA
    10,444
    Re: Any problem swimming in pool without pump operating
    It's ok! I swim in mine with and without the filter on.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,008
    They'll mix the water better than the filter will.
    Thanks. That was what I thought but I wanted to be sure.
    Casey's Avatar
    SW PA
    10,444
    No problem.
