Thread: Where did CYA go?
    May 2014
    Hunterdon County, NJ
    32
    Where did CYA go?
    When I started this whole process a few days ago my CYA was close to 90. I would estimate that I have had a 4-5" water exchange ending in 2 inches of rain as of this post. Is it possible for me to loose 10ppm of CYA with that?
    My evening test results are
    pH 7.5
    FC 9
    CC 0
    Ch 100
    Alk 140
    CYA 60
    I ran the CYA Test 4 times (dumping and refilling the tube)
    Everything else seems good, is this possible with that little water exchange?
    20500 gallon Grecian type 2 pool built in 1980's, Vinyl liner approx 2001
    2 Skimmers, 1 Dedicated Vac Line and 3 returns
    PureLine Prime PL2601 Pump - Hayward in line Chlorinator
    Triton TR-60 Sand filter
    Dolphin M3 robot, TF-100 with XL option & Speed Stir
    Casey's Avatar
    SW PA
    10,448
    Re: Where did CYA go?
    Yes it is. I lost 15ppm CYA in 2 days from dumping 4" of water off my pool and I expect to lose more. I started with 40 and now I'm at 25 so... It's possible. Just keep an eye on it.
