Thread: Stir my chlorine tank?
    Mar 2011
    SF bay area
    21
    I have peristaltic pump and 15 gal tank for liquid chlorine. I keep the tank at 8.25% concentration because that's how I usually buy bleach. From time to time I pickup 10% at Home Depot, in which case I add 27oz of water per gallon to get it back to 8.25%. I always assumed it would mix by diffusion, but then I saw the Liquidator floats a layer of water over the bleach. I don't understand how that works, but then the question is do I need to stir my tank after adding 10% and water?
    12,000 gal in-ground, blue granite pebble, Hayward Ecostar pump, 525 sqft cartridge filter, 250 sqft solar panels, TF100 test kit
    Casey's Avatar
    SW PA
    10,423
    Re: Stir my chlorine tank?
    The bleach is heavier than water... when you add bleach to the pool it's best to add it pencil thick over the return because it is heavier. Hope this explains why water would *float* on top. I'm sure if I'm incorrect, I'll be corrected. Lets see how I did...
    Mar 2011
    SF bay area
    21
    It does make sense that water will float on bleach, but it seems like eventually diffusion would mix them. Anyway my pool chemistry is stable so I'll just assume stirring isn't necessary.
    May 2013
    North East Ohio
    959
    Funny, I was about to post the same question...I thought water would MIX with the bleach, but now I am concerned that it won't.
    14,750 GAL IG Fiberglass (16 x 33) NE Ohio || Jandy 1HP 2 speed Pump || Waterco MultiCyclone 16 Centrifugal pre-filter (removed due to not working with sand filter) || 30" 575 Lb. Sand Filter || AquaCal 140K BTU Heat Pump || Solar Cover || Inter-fab Adrenaline Slide || GLI Monsoon Solar Cover Reel || K-2006C Test Kit || BBB with Liquid Chlorine Stenner Injection || Rayner Mighty Mesh Winter Cover
    Water and bleach will normally mix together, but it is possible to keep them from mixing for fairly long periods of time if you are careful. Still, it doesn't take much to get them to mix throughly, and once mixed they stay mixed. The Liquidator has a special setup to prevent turbulence at the boundary between bleach and water. Without that it is fairly difficult to keep them from mixing.
    May 2013
    North East Ohio
    959
    Cool so it sounds like us adding water to equalize the concentration will work thank you
