Results 1 to 7 of 7
Thread: yet another new pool user... i tried.. came close, but failed...
    May 2014
    gatineau, quebec, canada
    2
    So,
    like many others on this forum, bought a new house.. and it came with a pool.
    I have owned a spa for the last 4 years, and that, I have mastered extremely well and i learned the hard way that most pool stores are just out to get your money but suckering you with chemicals you don't need.
    When I found this site, it was a savior for the pool... I read every article I could find, and I have been trying to turn my pool from a grimey, slimey green pool that smelled like a family of cats died in it to a proper states.
    The pool spent the winter season without a cover, and the snow/ice finished melting about 3 ~ 4 weeks ago (very late spring for us this year). Looking at my backyard, you would tell me that I am in the middle of a huge forest, but I am in a city. I have been fighting with the net & vacuum for the last 2 weeks plus, and it feels like i'm winning, but its taking forever.
    Add to that, that there are still new houses getting build on my street so its throwing a lot of dust/sand in the air (and inevitably in the pool)
    now, the pool is no longer green, and it no longer smells like death, however i cannot see th bottom. The water has a white/greyish cloudyness to it, and that's what I cannot get rid of.
    I've been Slamming the poool (at least I think I have) and once... just once I caught a glimmer of the bottom, and was able to vacuum some of the garbage that was stuck down there; but after 10 minutes, the water was all murky again.
    1) The size of your pool in gallons: 11000 gallons (
    2) The type filter you have (sand, DE, cartridge) - I have a sand filter
    3) If your pool is an AG (above ground) or IG (in ground) Above ground, 24 feet diameter, 48 inches hight
    5) If you know, tell us the size pump and the size (flow rate) of your filter. (i'll go get that in a bit and Edit)
    FC - Free Chlorine 9ppm
    CC or TC - Combined Chlorine or Total Chlorine - No idea... stupid pool place does not test that ( i will be buying the proper test kit )
    pH - 7.3 (has been stable - been testing with strips, always in the 'sweet spot'
    TA - Total Alkalinity 140ppm
    CH - Calcium Hardness 230 ppm
    CYA - Cyanuric Acid (stabilizer/conditioner) 20ppm
    Any tips?
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,429
    Re: yet another new pool user... i tried.. came close, but failed...
    Hi, welcome to TFP! You may need to deep clean the sand filter since you don't know how well the filter was maintained before you bought the house. Otherwise keep the FC at 10 as long as possible with frequent additions of bleach and backwash the filter when you get a 20% rise over clean pressure. Keep the filter running 24/7 until the pool is clear. It can take a while to clear a dirty pool. Brush the pool daily to stir up the dead algae so the filter may catch it. You may want to try adding a little DE to the filter so it will catch finer debris. It will backwash out with the dirt so it must be reapplied to continue using it.
    Love TFP? Become a
    TFP Supporter!
    Casey's Avatar
    SW PA
    10,461
    You really need the test kit (TF100 XL)! You won't know if you're at SLAM level or not without it.
    Welcome to TFP!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Welcome!
    Two things: 1)This place has the monopoly on Taylor test kits in Canuckistan, so here's where you're stiuck buying the right one. Unless you ever crosss the border. 2) You might be a candidate to add DE to your sand filter. Only do it when you're going to be around to watch the pressure because I suspect it will load up awfully fast.
    May 2014
    2
    you folks are awesome... but ouch for the price for us canucks... sucks... but will probably bite the bullet and purchase it....
    i'm extremely thankful for folks like you!
    Richard320's Avatar
    Jan 2010
    19,074
    Quote Originally Posted by kilou View Post
    Hey, monopolies are great.... if you own it.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Even though it seems expensive, and it is for that, but it will still be the single best investment you make in your pool aside from gaining understanding.
    Welcome to the forum!
    Essential Links:
