Results 1 to 7 of 7
Thread: replacing pump fitting
    May 2008
    central Florida
    27
    I have a dura-glas P2R series pump that developed a crack in the fitting that attaches to the pump body discharge. the fitting is a 2" on the pipe side and 1.5" on the pump side (this is stamped on the fitting itself). I'm assuming the fitting threads into the pump body. the reason I say this is it appears there is a silicone based sealant (blue in color) that I can detect at that interface. when I first saw the sealant, it reminded me of RTV since I could press my fingernail into it and it had the feel of something rubberized/pliable.
    just to be clear, the fitting is cracked NOT the pump body.
    my main questions are: 1) are all my assumptions valid and what kind of silicone do I use when I replace the fitting? 2) also, do I have to remove every last morsel of old sealant from the pump body threads at the discharge? -- I guess what I'm asking is how clean do I need to make it before loading it up with new sealant and installing a new fitting?
    thanks
    12K gal PebbleTec, 1.5 HP 1-spd P2RA series Sta-Rite pump, Hayward cart filter, Pool Pilot SWG, spillway, no heater, sunny, Taylor K-2006 test kit.
    38,285
    Re: replacing pump fitting
    1. Yes the fitting screws in. You should not need any silicone, but use a good teflon pipe dope.
    2. Ideally you want most out ... if it is a silicone rubbery sealant, that may be more work to try to remove.
    May 2008
    central Florida
    27
    thanks jason ..... was able to pick up some Rectorseal Tru-Blu at home depot. it's teflon based and says it is specifically formulated for vibration areas -- I figured the outlet to the pump qualifies as a vibration area. not sure how long it takes to cure since the directions state it "varies with application". so, i went ahead and removed the old fitting and installed a new one using the tru-blu and replumbed the 2" line. the old sealant wasn't too hard to remove -- it was basically limited to the first few threads.
    38,285
    Make sure that pipe dope says it is for PVC and ABS, some can damage plastic.
    May 2008
    central Florida
    27
    right .... I checked the label beforehand -- says it's good to use on pvc, cpvc, PE and FRP plastic pipe
    38,285
    What are the pumps made of? I have read some multi valves are ABS and get weekened and crack from the wrong dope.
    May 2008
    central Florida
    27
    not sure what the pump housing halves are made of, but they kind of look like a fiber reinforced plastic or some kind of resin material ....
